Problemer med "digg spy" side jeg har
http://www.ludrio.no/forumet/spy/
Her er da problemet. Den skal vise 5 nyeste trådene fra forumet mitt. Og utifra dette skal den kun vise de, og når en ny tråd kommer, kommer den øverst og dytter den nederste ut.
I denne så viser den alle trådene. Den sirkulerer.
Her er koden:
Index
Klikk for å se/fjerne innholdet nedenfor
<?php
//DB Connection
mysql_pconnect("localhost", "****", "****");
mysql_select_db("****");
//Get the Sajax here
require("scripts/sajax.php");
//Execute the query to select from the table zips
function GET_zips($x) {
$q = "select topic_title, topic_id, topic_time, topic_views from phpbb_topics order by topic_time desc limit $x, 1;";
$sql = @mysql_query($q);
while($array = mysql_fetch_array($sql)){
return $result = $array[0] . " | " . $array[1] . " | " . $array[2] . " | " . $array[3] . " | " . $array[4];
sajax_init();
$sajax_debug = 0;
sajax_export("GET_zips");
sajax_handle_client_request();
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Ludrio Spy</title>
<script type="text/javascript">
sajax_show_javascript();
</script>
<script language="javascript" src="scripts/prototype.js"></script>
<script language="javascript" src="scripts/effects.js"></script>
<script language="javascript" src="scripts/spy.js"></script>
<script language="javascript"> columnsmax = 5; </script>
<style type="text/css">
#spy table {font:9px verdana,tahoma,arial,sans-serif;}
#spy div {margin-bottom:15px;}
#spy div:hover {background-color:#F5F7F7}
h3 img {cursor:pointer}
</style>
h3 { text-transform: uppercase }
</style>
</head>
<body onload="init()">
<img id="vsplay" src="images/play_down.gif" alt="Play" title="Play Comments" onclick="playVoteSpy();">
<img id="vspause" src="images/pause_up.gif" alt="Pause" title="Pause Comments" onclick="pauseVoteSpy();">
<table width="100%">
<tr valign="top\">
<td width="185">Tittel</td>
<td width="130">ID</td>
<td width="85">Klokken</td>
<td width="125">Visninger</td>
</tr>
</table>
<div id="spy">
<div id="comment-5"/></div>
<div id="comment-4"/></div>
<div id="comment-3"/></div>
<div id="comment-2"/></div>
<div id="comment-1"/></div>
</div>
</body>
</html>
Spy.js
var columnsmax;
var play = 0;
var zip;
var topic_views;
var population;
var topic_title;
var digit = 0;
function init() {
start();
function pauseVoteSpy() {
var playimg = document.getElementById("vsplay");
var pauseimg = document.getElementById("vspause");
playimg.src = "images/play_up.gif";
playimg.alt = "Start";
pauseimg.src = "images/pause_down.gif";
pauseimg.alt = "Pause...";
pause();
function playVoteSpy() {
playimg.src = "images/play_down.gif";
playimg.alt = "Viser..";
pauseimg.src = "images/pause_up.gif";
pauseimg.alt = "Pause";
resume();
function pause() {
play = 0;
function resume() {
play = 1;
function start() {
setTimeout("processDB()", 500);
function GET_zips_CB(result) {
var parts = result.split(" | ");
topic_views = parts[0];
zip = parts[1];
population = parts[2];
topic_title = parts[3];
push();
function processDB() {
x_GET_zips(digit, GET_zips_CB);
digit++;
setTimeout("start()", 2000);
function push() {
if (play == 0) {
setTimeout("push()", 1000);
return;
var cell;
var cellnext;
var text;
var style = "";
text = "<table width=\"100%\">"
text += "<tr valign=\"top\">";
text += "<td width=\"185\">"+topic_views+"</td>";
text += "<td width=\"130\">" + zip + "</td>";
text += "<td width=\"85\">" + population + "</td>";
text += "<td width=\"125\">" + topic_title + "</td>";
text += "</tr>";
text += "</table>";
Element.setOpacity('comment-1', 0.0);
for (i = (columnsmax - 1); i >= 1; i--) {
cell = document.getElementById("comment-" + i);
cellnext = document.getElementById("comment-" + (i + 1));
if (cell.innerHTML != "") {
cellnext.innerHTML = cell.innerHTML;
document.getElementById("comment-1").innerHTML = text;
Effect.Appear('comment-1', { duration: 1.5 });
if (pollids.length > 0) {
setTimeout("push()", 1550);
else {
setTimeout("start()", 5000);
Håper noen kan hjelpe!
