Noen som har hørt om Quickheal?
Gjest medlem-105082
Har hørt om det ja.
Bare noen review fra brukere.
Så regner med det ikke er så veldig kjent program.
Quickheal produseres forøvrig i India, så de fleste tester er vel på indiske sider ellerno.
Fant dette. Er fra 2004 da. Kommer på 42. plass av 50. Men mer finner ikke noe mer:
Klikk for å se/fjerne innholdet nedenfor
****10-25 August 2004 *****
The test was made on 10-25 August 2004, using Windows 2000 SP4 on a CELERON 2400 Mhz, 256MB DDRAM.
All programs tested had the latest versions, upgrades and updates and they were tested using their full scanning capabilities e.g. heuristics, full scan etc.
The 76556 virus samples were chosen using VS2000 according to Kaspersky, F-Prot, RAV, Nod32, Dr.Web, Sweep, BitDefender, E-Trust and McAfee antivirus programs. Each virus sample was unique by virus name, meaning that AT LEAST 1 antivirus program detected it as a new virus.
ALL virus samples were unpacked and the only samples that were kept were the ones that were packed using external-dos-packers (that means not winzip, winrar, winace etc).
The virus samples had the correct file extension using a special program (Renexts) and were unique, according to checksum32 filesize.
Most "fake" virus samples were removed, as well as "garbage" files.
The program PER was not tested because there was no english demo version available.
The programs BOClean , VET , Titan , RisingAV , Ikarus and Freedom were not tested because there was no demo version available.
The program InVircible did not include a "typical" scanner-function and could not be tested.
The program V-Catch checks only mail accounts and could not be tested.
The following file types were used.
BAT, ÂÉÍ, CLA, CLASS, CLS, COM, CSC, DAT, DOC, ELF, EML, EXE, HLP, HQX, HTA, HTM, IMG, INF, INI, JS, MAC, MDB, MSG, OLE, PHP, PIF, PL, PPT, PRC, REG, SCR, SH, SHS, SMM, STI, TD0, TPU, VBA, VBS, WBT, XLS, XMI, XML.
The virus samples were divided into these categories, according to the type of the virus :
File = BeOS, FreeBSD, Linux, Palm, OS2, Unix, BinaryImage, BAS viruses.
MS-DOS = MS-DOS and HLL*. viruses.
Windows = Win.*.* viruses.
Macro = Macro and Formula viruses.
Malware = DoS, Constructors, Exploit, Flooders, Hoax, Jokes, Nukers, Sniffers, Spoofers, Virus Construction Tools, Virus Tools, Corrupted, Droppers, Intended, PolyEngines.
Script = BAT, Corel, HTML, Java, Scripts, VBS, WBS, Worms, PHP, Perl viruses.
Trojans-Backdoors = Trojan and Backdoor viruses.
Rank
1. Kaspersky Personal Pro version 4.5.0.58 - 99.09%
2. F-Secure 2004 version 4.71.5 - 98.77%
3. Extendia AVK Pro version 11.0.4 - 98.68%
4. AVK version 14.0.7 - 98.50%
5. Kaspersky Personal version 5.0.149 - 97.88%
6. eScan 2003 Virus Control version 2.6.484.8 - 96.75%
7. McAfee version 8.0.41 - 93.59%
8. Norton version 2004 Professional - 93.38%
9. RAV version 8.6.105 - 93.14%
10. F-Prot version 3.15 - 91.85%
11. Command version 4.90 - 91.41%
12. Panda Titanium version 3.02.00 - 91.38%
13. Norton Corporate version 9.0.0.338 - 90.29%
14. Panda Platinum version 7.05.04 - 89.97%
15. MKS_VIR 2004 version 2.0 - 89.45%
16. Virus Chaser version 5.0 - 89.07%
17. BitDefender version 7.2 - 88.52%
18. BullGuard version 4.5 - 87.26%
19. Dr. Web version 4.31b - 85.35%
20. PC-Cillin 2004 version 11.00.1253 - 84.80%
21. Nod32 version 2.0.0.9 database 1.840 - 82.68%
22. Sophos Sweep version 3.84 - 81.31%
23. Avast version 4.1.418 - 80.55%
24. AntiVir version 6.27.00.01 - 79.57%
25. Vexira version 2.14.00.01 - 79.50%
26. AVG version 7.0.262 - 72.50%
27. Norman version 5.70.14 - 67.72%
28. UNA version 1.83 - 62.85%
29. Solo 2.5 version 2.6.3 - 61.08%
30. ZoneAlarm with VET Antivirus version 5.0.590.015 - 60.82%
31. Fire version 2.7 - 60.52%
32. E-Trust version 6.2.0.28 - 58.48%
33. V-Buster Pro - 57.61%
34. Protector Plus version 7.2.F04 - 51.28%
35. VirScan Plus version 14.091 - 48.36%
36. ClamWin version 0.35 - 48.08%
37. ViRobot Expert version 4.0 - 45.68%
38. MR2S version 1.47 - 44.36%
39. V3Pro 2002 Deluxe version SP2 - 42.33%
40. RHBVS version 4.13.656 - 41.99%
41. Digital Patrol version 5.00.08 - 38.52%
42. Quick Heal version 7.01 - 30.13%
43. Wave version 2.0 - 22.07%
44. TDS version 3.2.0 - 16.67%
45. PestPatrol version 4.4.3.24 - 15.34%
46. A Squared 2 - 15.05%
47. AntiTrojan Shield version 1.4.0.9 - 11.82%
48. PC Door Guard version 3.0.0.14- 11.77%
49. Trojan Hunter version 3.9.807 - 6.76%
50. The Cleaner version 4.1.42.52 - 6.34%
51. Trojan Remover version 6.2.8 - 5.62%
52. Tauscan version 1.6.1024 - 4.82%
53. Hacker Eliminator version 1.2 - 3.38%
54. IP Armor version 5.46.0703 - 2.87%
{title slightly edited (for accuracy) by zaldhie}
Endret av medlem-105082
Gjest medlem-105082
Du kan jo alltids laste ned trila versjonen på 30 dager å prøve. Det virker jo seriøst uansett om de kanskje ikke er så kjente.
Virusbulletin er noe alle antivirus programmer går gjennom. De fleste består. Noe som dette antivirus programmet gjør. Men det var ikke noen andre store "tester" på siden.
