Anonym5656 Skrevet 4. november 2006 Del Skrevet 4. november 2006 Har en linuxbox som skal KUN bruke TV'n som "skjerm". Har følgt litt etter en guide og kom frem til en slik config: Klikk for å se/fjerne innholdet nedenfor # /etc/X11/xorg.conf (xorg X Window System server configuration file)# # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "Files" FontPath "/usr/share/X11/fonts/misc" FontPath "/usr/share/X11/fonts/cyrillic" FontPath "/usr/share/X11/fonts/100dpi/:unscaled" FontPath "/usr/share/X11/fonts/75dpi/:unscaled" FontPath "/usr/share/X11/fonts/Type1" FontPath "/usr/share/X11/fonts/100dpi" FontPath "/usr/share/X11/fonts/75dpi" FontPath "/usr/share/fonts/X11/misc" # path to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" EndSection Section "Module" Load "i2c" Load "bitmap" Load "ddc" Load "dri" # Load "GLcore" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "no" Option "XkbOptions" "lv3:ralt_switch" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ExplorerPS/2" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "true" EndSection Section "InputDevice" Driver "wacom" Identifier "stylus" Option "Device" "/dev/wacom" # Change to # /dev/input/event # for USB Option "Type" "stylus" Option "ForceDevice" "ISDV4" # Tablet PC ONLY EndSection Section "InputDevice" Driver "wacom" Identifier "eraser" Option "Device" "/dev/wacom" # Change to # /dev/input/event # for USB Option "Type" "eraser" Option "ForceDevice" "ISDV4" # Tablet PC ONLY EndSection Section "InputDevice" Driver "wacom" Identifier "cursor" Option "Device" "/dev/wacom" # Change to # /dev/input/event # for USB Option "Type" "cursor" Option "ForceDevice" "ISDV4" # Tablet PC ONLY EndSection Section "Device" Identifier "Generic Video Card" Driver "savage" Option "TVOutFormat" "SVIDEO" Option "TVStandard" "PAL-G" Option "ConnectedMonitor" "SDM-S95D/FN" BusID "PCI:1:0:0" EndSection Section "Monitor" Identifier "SDM-S95D/F/N" Option "DPMS" HorizSync 30-50 VertRefresh 60 EndSection Section "Screen" Identifier "Default Screen" Device "Generic Video Card" Monitor "SDM-S95D/F/N" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 4 Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 8 Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 15 Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 16 Modes "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 24 Modes "800x600" "720x400" "640x480" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" InputDevice "stylus" "SendCoreEvents" InputDevice "cursor" "SendCoreEvents" InputDevice "eraser" "SendCoreEvents" EndSection Section "DRI" Mode 0666 EndSection Men når jeg kobler til TVn får jeg veldig flimmrete og svart/hvitt bilde. På LCD-skjermen går det fint. Noen peiling på hva som er galt? Eller kanskje en annen "TV-mal" jeg kan gå etter? Lenke til kommentar
