Eide'n Skrevet 2. november 2006 Del Skrevet 2. november 2006 (endret) I dag blei ForceWare 93.71 sluppet. last ned her XP/2000 direkte til U.S. Engelsk Direkte Til multi-språk(med norsk) Endret 2. november 2006 av King[nor] Lenke til kommentar
Eide'n Skrevet 2. november 2006 Forfatter Del Skrevet 2. november 2006 Issues Resolved in Version 93.71The following are changes made and issues resolved since driver version 91.45: Resolved Issues for 32-bit Operating Systems Single-GPU Issues Resolved • Error message occurs when running the NVIDIA Control Panel Television Setup Wizard. • NVIDIA Quadro FX 4400: After changing the color settings from the NVIDIA Control panel, the settings revert to the default. • GeForce 7950 GX2, NVIDIA Control Panel: The Multi-GPU performance mode default is set to Custom when initially creating a new application profile. • GeForce 7950 GX2: In the NVIDIA Control Panel, Multi-GPU antialiasing modes are available when Multi-Display rendering mode is selected. • GeForce 7900 GT: The new NVIDIA Control Panel lists the product name as GeForce 7900 GT/GTO, instead of the correct GeForce 7900 GT. • GeForce 7600 GS, NVIDIA Control Panel/Classic Control Panel: HDTV component-out output is split vertically when applying the 1080i resolution. • GeForce 7600 GS, GeForce 6150/6100: During video playback in VMR mode, video is corrupt and shaky when noise reduction is enabled. • GeForce 6800 GT 256MB: Windows Media Player 10 video becomes corrupt when rotating the screen while playing a video. • GeForce 6600 128MB: Windows Media Player 10 crashes when changing the resolution while playing a DVD. • GeForce 6600 128MB: The secondary Dualview monitor flickers while playing any NTSC DVD. • GeForce 6600 128MB: The NVIDIA Control Panel crashes while changing the desktop configuration after changing the video color settings. • GeForce 6600, Windows XP Media Center Edition: While playing MCE Live TV in Clone mode with full-screen video mirror, the mirrored display is corrupted when resizing the application. • GeForce 7300 GT, GeForce 6150/6100: HQV objects flutter and the test bar splits when noise reduction is enabled. SLI Issues Resolved • GeForce 7950 GX2 Quad NVIDIA SLI, NVIDIA Control Panel: Enabling or disabling “Show SLI Visual Indicators” when “Adjust Image Settings with Preview” page is open causes the NVIDIA Control Panel to crash. • GeForce 7950 GX2, Quad NVIDIA SLI, NVIDIA Control Panel: Unable to preserve Custom AA setting for Direct3D application profiles. • GeForce 7950 GX2 512MB, Quad NVIDIA SLI: EverQuest–blue- screen crash occurs when exiting the game. • GeForce 7950 GX2, SLI: After enabling and then disabling SLI mode, Display # 4 loses sync. • GeForce 7950 GX2, GeForce 6600, SLI: Spellforce 2–flickering corruption occurs during game play. • GeForce 7900 GTX, SLI System: Dungeon Siege 2–with SLI mode enabled, there is graphics corruption when 8x antialiasing is enabled. • GeForce 7900, GeForce 6800, SLI System: World of Warcraft–with SLI mode enabled, there are missing character portraits. • GeForce 7600 GT 256MB, SLI: TimeShift–corruption occurs at the start of the game when the resolution is set to 1280x1024. • GeForce 7300 GT, SLI: Spellforce 2– flickering, multicolored triangles appear in the terrain when SLI is enabled. Resolved Issues for 64-bit Operating Systems Single-GPU Issues Resolved • 233027 VFA 91.47 Quadro FX4500 X2, Window XP x64: The Classic NVIDIA Control Panel->Edge Blending page is missing. • 233172 still open in 91_21 GeForce 7950 GX2, Windows XP x64: The NVIDIA Control Panel Application-Preferred antialiasing setting leaves antialiasing unchanged and overrides the application setting • 232364 GeForce 7950 GX2, Windows XP x64: You cannot switch fro CRT to DFP using the NVIDIA Control Panel. • 225618 GeForce 6150/6100 64 MB, Windows XP x64: Corruption occurs when running the Direct Draw test from the DirectX Diagnostic tool. • 226631 GeForce 6100/6150, Windows XP x64: Video is corrupted if MPEG2 HD transport/program streams are played in lower screen resolutions. Lenke til kommentar
HKS Skrevet 2. november 2006 Del Skrevet 2. november 2006 For dere som lurer på det så er en av nyhetene i denne driveren hardware offisiel støtte for HD-dekoding (PureVideo HD) http://www.nvidia.com/page/purevideo.html - Hardware acceleration of H.264, VC-1 and MPEG-2 HD movie formats. - Video post-processing image enhancements. - Built-in support for HDCP content protection protocol via DVI or HDMI connectors. Lenke til kommentar
DuckDuckGoose Skrevet 24. november 2006 Del Skrevet 24. november 2006 Jeg har et gf 6600 skjermkort, og prøvde å oppdatere driveren til den nyeste nå. Men når jeg restarter maskinen, får jeg bare en svart skjerm... Hva er galt? Støtter ikke kortet mitt disse driverne? Lenke til kommentar
Octavian Skrevet 2. desember 2006 Del Skrevet 2. desember 2006 vekker opp denne igjenn. Har et XFX gf6800 Når jeg prøver og legge inn disse driverene restarter pcn ca midt under installasjonen. Tenkte kansje det var no kødd etter de forige driverne. Så jeg formaterte maskinen, å la inn sp2, Nforce4 drivere for amd (6.86) og prøvde så med disse, samme ressultat. annyone? Lenke til kommentar
Octavian Skrevet 2. desember 2006 Del Skrevet 2. desember 2006 liten uppdate, på Bluescreen saken er det filen "nv4_mini.sys" som er problemet. det er når skjermen blinker, slik den plaier og gjøre under installasjonen at den bestemmer seg for og restarte. noen som har tips eller kunnskap om hvordan jeg kan få det til og funke? Lenke til kommentar
Chevelle Skrevet 3. desember 2006 Del Skrevet 3. desember 2006 Bruker disse i den ene pc'en med 2X 6600GT i SLI. Ikke noe problemer med 93.71 så langt. Er du i tvil hvilke kort som er støttet i nyeste drivere fra nVidia finner du info om dette her. Lenke til kommentar
Stig Jøran Skrevet 3. desember 2006 Del Skrevet 3. desember 2006 Hm, la inn drivern nettop, og rebootet, fikk da opp at Minne på mitt 7800gt er på 2ghz?? Noe er rart her Lenke til kommentar
Theoneask Skrevet 3. desember 2006 Del Skrevet 3. desember 2006 Shit drivar 2k6. Har eit 6800LE, dersom eg instalerer den blir skjermen svart og pcen restarter. Når den starter opp igjen er skjermen full av streker og restarter igjen raskt. Sånn er det med alle drivare for meg av ein eller anna grunn, men skjedde først med den der. Lenke til kommentar
