MindTooth Skrevet 29. oktober 2006 Rapporter Del Skrevet 29. oktober 2006 Microsoft is banning 360 firmware modders After several months of silence it was more or less accepted that Microsoft wasn’t going to do anything about the firmware hacks that allow Xbox 360s to play backups. Rather surprising, considering the ‘inventor’ of the hack confirmed in March already that the mods are easily detectable, and the reports that piracy is running rampant in countries like China. It appears that Microsoft is finally taking action against them though, although they may be hitting the wrong persons. Kilde: Xboxic Lenke til kommentar
_norse_ Skrevet 29. oktober 2006 Rapporter Del Skrevet 29. oktober 2006 Godt å høre at det blir gjort noe... Lenke til kommentar
kewell79 Skrevet 29. oktober 2006 Rapporter Del Skrevet 29. oktober 2006 There is something slightly fishy about the report though, being that it says the 360 is banned based on MAC address. Those of us familiar with the OSI model and common network implementations will immediately know this is not true, because MAC addresses are part of the Ethernet protocol and live on Layer 2, and never get routed over the internet. In simple terms: your 360s MAC address is not remotely identifiable. An option could be that the Xbox Live login code sends the MAC address itself to the Live servers to be able to uniquely identify the 360, but that would be plain silly since MAC addresses are known not to be unique: they only need to be unique within their physical subnet. A far more obvious solution on Microsoft’s part would be to use the console serial number for this, which is embedded in the system anyway and truly unique. Lenke til kommentar
MindTooth Skrevet 29. oktober 2006 Forfatter Rapporter Del Skrevet 29. oktober 2006 Og med sitatet mener du hva? Lenke til kommentar
kewell79 Skrevet 29. oktober 2006 Rapporter Del Skrevet 29. oktober 2006 (endret) at det er noe fishy vel Når første personen blir bannet skal jeg personlig skrive det her + det er bare å følge med på under "Spørsmål og svar - Konsoll" , dere ser nok hva topicen heter når folk begynner skrike der, DA har det skjedd Endret 29. oktober 2006 av kewell79 Lenke til kommentar
-sparks- Skrevet 29. oktober 2006 Rapporter Del Skrevet 29. oktober 2006 har ikke merket noe her ivertfall og med tanke på hvor mye jeg sparer(som jeg kan bruke på ps3+wii så er microsoft live ett lett offer jaja, får nyte multiplayer maks så lenge det varer Lenke til kommentar
Gjest Slettet-t9DveYkZ Skrevet 29. oktober 2006 Rapporter Del Skrevet 29. oktober 2006 Det skulle da egentlig bare mangle at det ikke ble gjort noe. Microsoft bør ha vært klare over dette en ganske god stund, og kan da ha brukt tiden på å samle inn serienummere/hvaenndenåbruker for så å begynne å slenge ut massive bans. Tiden vil vel uansett vise hvorvidt de faktisk tar store skritt for å hindre dette, jeg antar vi kommer til å se ganske mye whining på forumene isåfall. Lenke til kommentar
BlastyTrasty Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 Godt å høre at det blir gjort noe... 7179559[/snapback] Stemmer. Hadde eg laga ein konsoll, hadde eg lagt inn ein self-destruct sak. Så når det blei oppdaga 'tampering' - blei det sendt ein slags kommando, som liknar på wake on lan, og så hadde ein viktig komponent i maskina tatt kveld. Oi, har du modda den sa du? NO WARRANTY ASSHAT! :!: Lenke til kommentar
_norse_ Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 Godt å høre at det blir gjort noe... 7179559[/snapback] Stemmer. Hadde eg laga ein konsoll, hadde eg lagt inn ein self-destruct sak. Så når det blei oppdaga 'tampering' - blei det sendt ein slags kommando, som liknar på wake on lan, og så hadde ein viktig komponent i maskina tatt kveld. Oi, har du modda den sa du? NO WARRANTY ASSHAT! :!: 7180505[/snapback] hehe, det kan virke som om MS har lagt inn en slik funksjon, men den ser ut til å ramme fler enn bare de som har modda den Lenke til kommentar
frostbitten Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 hehe, det kan virke som om MS har lagt inn en slik funksjon, men den ser ut til å ramme fler enn bare de som har modda den 7180600[/snapback] Har ikke det vært typisk MS i det siste? Lenke til kommentar
Ghaundan Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 Det skulle da egentlig bare mangle at det ikke ble gjort noe.Microsoft bør ha vært klare over dette en ganske god stund, og kan da ha brukt tiden på å samle inn serienummere/hvaenndenåbruker for så å begynne å slenge ut massive bans. Tiden vil vel uansett vise hvorvidt de faktisk tar store skritt for å hindre dette, jeg antar vi kommer til å se ganske mye whining på forumene isåfall. 7179781[/snapback] Er nok sant det blir syting, men med tanke på at samme gruppe mennesker sikkert ville syte over at smerte etter å ha skutt seg selv i foten så kan man vel si de har fått som fortjent. Om microsoft banner folk ved å bruke MAC adressen er det jo en fare for at andre, legitime brukere blir straffet. Får nesten håpe MS gjør dette på en litt mer elegant måte, hvis ikke ryker mye av respekten jeg har for de. Lenke til kommentar
Gjest Slettet-p4PIYwb6 Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 Så man kan bli bannet fra Xbox Live? Lenke til kommentar
Ghaundan Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 Om man har flashed sin 360, ja. Er vel egentlig å forvente når man gjør slikt er det ikke? Lenke til kommentar
Vice Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 According to MS customer support my status codes indicate that I have MODDED 360’s which I don’t. Haha, genialt Microsoft, genialt. Kanskje en idé å sjekke hvem som faktisk har en modda boks før dere prøver å banne?? Lenke til kommentar
ØysteinT Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 According to MS customer support my status codes indicate that I have MODDED 360’s which I don’t. Haha, genialt Microsoft, genialt. Kanskje en idé å sjekke hvem som faktisk har en modda boks før dere prøver å banne?? 7180863[/snapback] Eller så kan det hende at han faktisk har moddet den, og forsøker å fremstå som uskyldig. Lenke til kommentar
Gjest Slettet-p4PIYwb6 Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 Om man har flashed sin 360, ja. Er vel egentlig å forvente når man gjør slikt er det ikke? 7180851[/snapback] Jepp, lurte bare på om de sprengte Xbox'n din eller noe sånt. Lenke til kommentar
Ghaundan Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 Vel, det står "banned from live or worse" men tviler nok på at 360 plutselig tikker ned for så å sprenge halve huset i lufta eller skyte laser stråler etter deg. Derimot virker det som de ikke har fått til denne banningen helt, om man skal tro alt i den artikkelen. Får bare håpe det er noe midlertidig. Lenke til kommentar
Vice Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 (endret) According to MS customer support my status codes indicate that I have MODDED 360’s which I don’t. Haha, genialt Microsoft, genialt. Kanskje en idé å sjekke hvem som faktisk har en modda boks før dere prøver å banne?? 7180863[/snapback] Eller så kan det hende at han faktisk har moddet den, og forsøker å fremstå som uskyldig. 7180893[/snapback] Eller så kan det hende at jorda er flat. Er vel ikke første gang Microsoft "fucker opp" med betalende kunder for å si det sånn. Endret 30. oktober 2006 av Vice Lenke til kommentar
BlastyTrasty Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 De bruker sjølvklart ikkje MAC addresser. Microsoft har vært i bransjen såpassa lenge at dei veit at dette er lett å spoofe. Dei brukar sjølvsagt serienummeret på XBOXen som sikkert er hakket værre å tukle med. Lenke til kommentar
Vice Skrevet 30. oktober 2006 Rapporter Del Skrevet 30. oktober 2006 De bruker sjølvklart ikkje MAC addresser. Microsoft har vært i bransjen såpassa lenge at dei veit at dette er lett å spoofe.Dei brukar sjølvsagt serienummeret på XBOXen som sikkert er hakket værre å tukle med. 7180963[/snapback] Det var jo akkurat det som ikke hang helt på greip : Although, he did confirm that the status codes I received indicate that my systems Mac addresses are banned because their supposedly MODDED. Lenke til kommentar
