0mr Skrevet 29. oktober 2006 Del Skrevet 29. oktober 2006 coil?? hva er det og ka gjør,hvor ligger det , hvor mange er det? Lenke til kommentar
PerB Skrevet 29. oktober 2006 Del Skrevet 29. oktober 2006 Fra Wikipedia: An ignition coil (also called a spark coil) is an induction coil in an automobile's ignition system which transforms a storage battery's 12 volts to the thousands of volts needed to spark the spark plugs. This specific form of the autotransformer, together with the contact breaker, converts low voltage from a battery into the high voltage required by spark plugs in an internal combustion engine. In older vehicles a single (large) coil would serve all the spark plugs via the ignition distributor. In modern systems, the distributor is omitted and ignition is instead electronically controlled. Much smaller coils are used with one coil for each spark plug or one coil serving two spark plugs (so two coils in a four-cylinder car). These coils may be remote-mounted or they may be placed on top of the spark plug (coil-on-plug or Direct Ignition). Where one coil serves two spark plugs (in two cylinders), it is through the "wasted spark" system. In this arrangement the coil generates two sparks per cycle to both the cylinders. The fuel in the cylinder that is nearing the end of its compression stroke is ignited, whereas the spark in its companion that is nearing the end of its exhaust stroke has no effect. The wasted spark system is more reliable than a single coil system with a distributor, and cheaper than coil-on-plug. Where the coils are remote mounted they may all be contained in a single moulded block with multiple high-tension terminals. This is commonly called a coil-pack. Hvor: I motorrommet. Hvo mange: en. Lenke til kommentar
Stjernestøv Skrevet 30. oktober 2006 Del Skrevet 30. oktober 2006 Fra Wikipedia:An ignition coil (also called a spark coil) is an induction coil in an automobile's ignition system which transforms a storage battery's 12 volts to the thousands of volts needed to spark the spark plugs. This specific form of the autotransformer, together with the contact breaker, converts low voltage from a battery into the high voltage required by spark plugs in an internal combustion engine. In older vehicles a single (large) coil would serve all the spark plugs via the ignition distributor. In modern systems, the distributor is omitted and ignition is instead electronically controlled. Much smaller coils are used with one coil for each spark plug or one coil serving two spark plugs (so two coils in a four-cylinder car). These coils may be remote-mounted or they may be placed on top of the spark plug (coil-on-plug or Direct Ignition). Where one coil serves two spark plugs (in two cylinders), it is through the "wasted spark" system. In this arrangement the coil generates two sparks per cycle to both the cylinders. The fuel in the cylinder that is nearing the end of its compression stroke is ignited, whereas the spark in its companion that is nearing the end of its exhaust stroke has no effect. The wasted spark system is more reliable than a single coil system with a distributor, and cheaper than coil-on-plug. Where the coils are remote mounted they may all be contained in a single moulded block with multiple high-tension terminals. This is commonly called a coil-pack. Hvor: I motorrommet. Hvo mange: en. 7177245[/snapback] Lenke til kommentar
Simkin Skrevet 30. oktober 2006 Del Skrevet 30. oktober 2006 (endret) Hvor: I motorrommet.Hvo mange: en. ikke nødvendigvis bare en.. Endret 30. oktober 2006 av Nish Lenke til kommentar
Tumbleweed Skrevet 30. oktober 2006 Del Skrevet 30. oktober 2006 Hvor: I motorrommet.Hvo mange: en. ikke nødvendigvis bare en.. 7186341[/snapback] Stemmer, min MC har en coil pr tennplugg/sylinder. Lenke til kommentar
chris Skrevet 30. oktober 2006 Del Skrevet 30. oktober 2006 Kort og godt på norsk. Coilens oppgave er å omforme bil- batteriets lavspente strøm (6 eller 12 volt) til høyspent strøm til tennpluggene. Lenke til kommentar
PerB Skrevet 31. oktober 2006 Del Skrevet 31. oktober 2006 Stemmer, min MC har en coil pr tennplugg/sylinder. 7186543[/snapback] Men dette er postet i forum for bil / bilteknisk. Og svaret er gitt ut fra hva som er vanlig. Lenke til kommentar
Tumbleweed Skrevet 31. oktober 2006 Del Skrevet 31. oktober 2006 Stemmer, min MC har en coil pr tennplugg/sylinder. 7186543[/snapback] Men dette er postet i forum for bil / bilteknisk. Og svaret er gitt ut fra hva som er vanlig. 7187976[/snapback] Oh brother....... Lenke til kommentar
Stonescream Skrevet 31. oktober 2006 Del Skrevet 31. oktober 2006 Har 6 stk jeg på mi kjærre. ( BMW ) Lenke til kommentar
