Judaz Skrevet 9. november 2002 Forfatter Del Skrevet 9. november 2002 Joda, det har jeg gjort 20 ganger. - Judaz - Lenke til kommentar
raffen Skrevet 9. november 2002 Del Skrevet 9. november 2002 Ville ha byttet hovedkort... Har du forsøkt å slå av alt "unødvendig" som strømstyring, paralell og serieporter også videre som du for øyeblikket ikke bruker? Litt mer om ACPI: When installing XP as an ACPI PC on an APIC motherboard, it doesn't matter what the "Plug and Play OS" setting is in your BIOS. XP will override this anyway. Microsoft actually recommend setting this to "No" regardless. If you do decide to install as a "Standard PC", then follow the steps below. Firstly, the entry Plug and Play OS in your motherboard's BIOS should be set to 'NO'. Click here to find out why. During installation of the XP operating system, you will see a screen displaying the message - "Press F6 if you need to install a third-party SCSI or RAID driver". At this point, press the F5 key (this won't be supplied as an option on the screen and the installation won't wait, so you'll need to babysit the installation process and hit the key at the right moment). A few seconds after pressing F5, you will be presented with an option to select either "Standard PC" or "Other (ACPI) PC". At this point, select "Standard PC". If you have already installed XP with ACPI, then you can change to "Standard PC" in the device manager afterwards. However, this method doesn't appear to be as effective as disabling it during the install. To do this, Start > Settings > Control Panel > System > Hardware Tab > Device Manager. Expand the Computer at the top of the list and right click the ACPI Computer > Drivers > Update Drivers > Select List > Standard PC. Note that when you reboot your PC, you will need to re-install all of your device drivers again. Lenke til kommentar
Tåkefyrste Skrevet 9. november 2002 Del Skrevet 9. november 2002 Hadde ca. samme problem selv, fikk løst dette med å sette "Memory Timing" i bios fra "Turbo" til "SDRam 810ns" eller "normal" _________________ Thunderbird 1.40Ghz (266fsb) Abit KT7A Yamaha 24x10x40x CDRW 512mb Winbond cas2 PC133 SDRAM Soundblaster Audigy Player Retail Radeon 8500 LELE 230230mhz 3.6ns SONY CPD-E430 19" Trinitron 55gb ATA100 7200rpm HD Telenor ADSL [ Denne Melding var redigert av: apollox på 2002-11-09 15:27 ] Lenke til kommentar
ripset Skrevet 9. november 2002 Del Skrevet 9. november 2002 Juster minneinnstillingene i bios. Lenke til kommentar
Judaz Skrevet 9. november 2002 Forfatter Del Skrevet 9. november 2002 Ja men jeg har gjort det for lenge siden. - Judaz - Lenke til kommentar
Play535 Skrevet 10. november 2002 Del Skrevet 10. november 2002 Jeg tror det er hovedkortet... kanskje det er noe feil med prossesoren, kanskje hovedkortet ikke er beregnet for så mye??? eller kanskje ikke. Lenke til kommentar
Judaz Skrevet 10. november 2002 Forfatter Del Skrevet 10. november 2002 Hvis det er hovedkortet, så må det være hovedkortet i kombinasjon med noe, Siden jeg har prøvd flere hovedkort av samme type. CPU har jeg jo bytta opptil flere ganger, så det tror jeg ikke det er og hovedkortet er beregnet for så mye, det vet jeg. Som jeg tidligere fikk tips om, har jeg skrudd av det alt av integrated peripherials som jeg ikke bruker, LPT, com porter etc. å maskina har ikke hengt siden. Har ikke hatt anledningen til å rævkjøre den maksimalt enda, men vi får se hvordan det går. Takk for all hjelp så langt :smile: - Judaz - Lenke til kommentar
verwooks Skrevet 11. november 2002 Del Skrevet 11. november 2002 Kanskje det er noe annet som påvirker maskinen din ? .. Prøv å flytt hele greiene over til et annet rom eller i et annet hus eller noe. Vi må prøve alt ikke sant ? hehe Lenke til kommentar
