Olum Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Administratorene på filmjournalen har ikke vært aktive på noen år. Det skjer også at jeg ikke finner filmer, eller de har helt feil navn. Lenke til kommentar
Montag Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 (endret) Jeg vurderer å bestille Nosferatu fra PK.no. Burde jeg bestille denne eller denne? Den ene varer litt lengre, menn den er 70,- dyrere. Som samler ville jeg gått for MoC sin utgave. Den er dog svindyr på PK, men kan skaffes billigere hos f.eks. Play. Som andrevalg er Kino sin utgave brukbar nok. Hva som er likt mellom disse to utgavene: 1) Both use the 2007 restoration by the F. W. Murnau-Stiftung. 2) Both are interlaced although the MoC is far less noticeable (see combing samples in very last capture). 3) Both are in the full-frame 1.33 aspect ratio for most of the film (segments appear pillarboxed). 4) Both are 2 disc packages with double thick keep cases (MoC has overlapping disc holders - Kino separate compartments). 5) Both offer the original German intertitles and both offer the Hans Erdmann score in 5.1 stereo (NOTE: Kino's first disc offers the film with English translated intertitles). 6) Supplement-wise they both give The Language of Shadows — a 53-minute German documentary by Luciano Berriatúa and both give the 3-minute short on the restoration process. 7) Both have the same running time - We suspect that the companies both made their masters from sources running at the original speed of 18 fps. --------------------------------------------------------------------------------- Hva som er forskjellig: 1) The Eureka MoC disc is in the PAL standard (region 0). The Kino is in the NTSC standard (also region 0). 2) The MoC appears to have superior compression with far less artifacts than both Kino versions but the Kino tends to look sharper at times. I'm unsure why this is. 3) MoC's original German intertitle version is on a dual-layered disc sharing only with commentary. Kino original German intertitles edition (second disc) is on a single-layered edition. 4) Supplements - MoC have added a very worthwhile commentary and a gorgeous 80-page liner notes booklet. Kino added excerpts from other Murnau films and a photo gallery. 5) Contrast and color tinting can be slightly different in the two releases. 6) The MoC shows more information in the frame. Endret 4. mars 2009 av Montag Lenke til kommentar
Coffey Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Første kommentaren fra en jente etter å ha sett Into The Wild med klassen; "Var det ekte... lizzm?" Lenke til kommentar
Xanman Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 (endret) .... Takk for svaret! Endret 4. mars 2009 av GoreGalore Lenke til kommentar
Bob_3 The Builder Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Takk for quoten Noen som har en formening om hvilken animasjonsfilm som er best av Bee Movie, Horton Hears A Who! og Happy Feet? Lenke til kommentar
Gjest Slettet-D7I5Gr2 Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Har sett bare to av de nevnte,men Bee Movie trekker det lengste tråden for meg. Men den er ikke bra. Lett glemt. Happyfeet har skuespillerne men er for langsom,samt drittlei animerte(og ikke animerte) pingviner. Lenke til kommentar
CCola Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Faktisk ikke sett noen av dem, så jeg er også interessert i å vite om noen i det hele tatt er bra? Lenke til kommentar
Xanman Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Jeg har bare sett Bee Movie, og den er faktisk veldig artig. Bare pass på at du ikke ser den med norsk tale, da Jerry Seinfelds stemme er noe av det beste med hele filmen. Lenke til kommentar
MsGreen Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Noen som har en formening om hvilken animasjonsfilm som er best av Bee Movie, Horton Hears A Who! og Happy Feet? Lenke til kommentar
Bob_3 The Builder Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Allright. Tenkte å skaffe meg en animasjonsfilm på blåstråle, og det var de 3 første animasjonsfilmene jeg fant med 5 stjerner på hi-def digest. Lurer på å gå for Bee Movie. Time will tell. Lenke til kommentar
Halvt horn ost skinka piffi varmt Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Allright. Tenkte å skaffe meg en animasjonsfilm på blåstråle, og det var de 3 første animasjonsfilmene jeg fant med 5 stjerner på hi-def digest. Lurer på å gå for Bee Movie. Time will tell. Ratatouille! Fantastisk bilde med blåstråle (og ganske grei film også). Lenke til kommentar
tjalla Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Hadde virkelig kjøpt Ratatouille og WALL-E framfor de tre du nevner. De har også fem stjerner. Lenke til kommentar
Bob_3 The Builder Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Ja, men de har jeg på dvd. Lite keen på å kjøpe titler jeg allerede har, men jeg skal vel alltids klare å "bli kvitt" dvdene. Lenke til kommentar
Dorian Gray Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Happy Feet er jo søt, men Wall-E er en film man faktisk kan se flere ganger. Lenke til kommentar
Mojo Pin Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Nå var ikke jeg superimponert av Wall-E jeg da.. Absolutt på et godt Pixar-nivå, men ikke av de bedre. Liker til sammenligning Ratatouille, Finding Nemo og Toy Story mye bedre! Lenke til kommentar
DoktorBacon Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Rottatouille var flott å se på, men ganske by-the-books. Wall-E var derimot en mer spesiell og særegen Pixar-film. Lenke til kommentar
tjalla Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Rottatouille var flott å se på, men ganske by-the-books. Wall-E var derimot en mer spesiell og særegen Pixar-film. Det er som du sier, de har noe forskjellig ved seg. Ratatouille er som Shawshank Redemption... en perfeksjonering av sin sjanger. Langt ifra revolusjonerende men gjør rett og slett greia si så perfekt. WALL-E er først og fremst en herlig samfunnskritisk film. Forøvrig de to Pixarfilmene jeg setter øverst. Lagde en liste i listefebertråden nå. Lenke til kommentar
Gjest Slettet+9817234daf Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Rottatouille var flott å se på, men ganske by-the-books. Wall-E var derimot en mer spesiell og særegen Pixar-film. Det er som du sier, de har noe forskjellig ved seg. Ratatouille er som Shawshank Redemption... en perfeksjonering av sin sjanger. Langt ifra revolusjonerende men gjør rett og slett greia si så perfekt. WALL-E er først og fremst en herlig samfunnskritisk film. Forøvrig de to Pixarfilmene jeg setter øverst. Lagde en liste i listefebertråden nå. Veldig enig i det du sier om Ratatouille. Likte den bedre enn WALL-E. En del bedre. Lenke til kommentar
Montag Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Det er for ordens skyld ingenting som tyder på at eksplosjoner utelukker filosofi. Matrix var fylt med slow-mo action, kampsport, eksplosjoner og det som er men er i bunn og grunn bygget på Platons hulelignelse. Filosofiske filmer med rolig tempo er særdeles uorginalt. Skal vi snakke om rullebåndsproduksjon så er det nettopp det det blir hvis man ikke åpner opp for utvikling. Om man først skal sette litt perspektiv på den ellers så uorginale kritikken. Det trengs noe mer for å fenge i dag, hvorfor Montag tilsynelatende ønsker at folk skal tråkke i de samme gamle skoene og reprodusere det andre alt har perfeksjonert vet han nok best selv (og han kan korrigere meg om jeg tolker feil). Kreativt forslag kan det ikke beskyldes for å være, eller? Jeg vil kalle det konservativt og stagnasjon å se seg tilbake på den måten. Termintator Salvation kan fint klare seg selv som en filosofisk perle selv med gigantiske roboter og store eksplosjoner. Rent personlig ønsker jeg noen som tar det hele et steg videre velkommen, fremfor å ønske at man skal prøve å gjenta Terminator 1 eller 2. Men dette er McG og ikke Cameron, så jeg forblir fortsatt skeptisk. Men traileren var knall Hehe, svært så ivrig du er etter å legge ord i min munn, dotten. Jeg har aldri sagt at jeg ønsket en resirkulering av noe som helst i denne saken. Mitt poeng var bare at jeg håpet gutta bak T4 har latt det være rom også for den gode historien, og ikke - som traileren sterkt kunne tyde på - bare fokuserte på storslagen cgi og høylytte smellsekvenser i verste Baystil. I så fall kan vi med rette snakke om samlebåndsproduksjoner! Er det galt å ytre ønske om litt mer originalitet enn som så? Jeg er dog enig med din skepsis angående McG - dette kan fort bli en crapfest uten like, Bale or no Bale... Lenke til kommentar
DannyVice Skrevet 4. mars 2009 Rapporter Del Skrevet 4. mars 2009 Er det noen som har noen tips til noen gode filmsider med "video-reviews eller video-podcasts"..Altså der det er video, og ikke bare tekst å lese Lenke til kommentar
