Iris_L Skrevet 23. oktober 2006 Del Skrevet 23. oktober 2006 Noen som kan si meg hva som er galt, eller rettere sagt hvordan jeg kan fikse det? Warning: include(http://bettersaf.frac.dk/bettersafe/editor/phpnews_1-3-0/news.php) [function.include]: failed to open stream: Connection refused in /web/www/frac/users/b/bettersaf/bettersafe/Simple_Tabs/index.php on line 34 Warning: include() [function.include]: Failed opening 'http://bettersaf.frac.dk/bettersafe/editor/phpnews_1-3-0/news.php' for inclusion (include_path='.:/usr/share/php:/usr/share/pear:/web/www/include') in /web/www/frac/users/b/bettersaf/bettersafe/Simple_Tabs/index.php on line 34 Ja, jeg er totalt blank Slik ser selve innholdet ut: <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <link rel="stylesheet" title="Style" href="style.css" type="text/css" media="screen"> <link rel="stylesheet" href="print.css" type="text/css" media="print"> <meta http-equiv="Content-Type" content="application/xhtml+xml; charset=windows-1252"> <title>Vår hjemmeside</title> </head> <body> <div class="main"> <h1 id="header"> <span style="color: rgb(107, 61, 33);">Vår hjemmeside!</span><span id="tagline"></span> </h1> <div class="menu"> <ul> <li><a class="current" href="#">Home</a></li> <li><a href="#">Menneskene</a></li> <li><a href="#">Cleo</a></li> <li><a href="#">Pia</a></li> <li><a href="#">Drill</a></li> <li><a href="#">Blogg</a></li> <li><a href="#">Gjestebok</a></li> <li><a href="#">Album</a></li> <li><a href="#">Kontakt oss</a></li> <li><a href="#">Linker</a></li> </ul> </div> <div class="content"> <h2>Velkommen</h2> <br> <?php include("http://bettersaf.frac.dk/bettersafe/editor/phpnews_1-3-0/news.php"); ?> <br> </div> <br> </div> </body> </html> Link til siden: http://bettersaf.frac.dk/bettersafe/Simple_Tabs/index.php Jeg prøver å sette inn PHPNews Lenke til kommentar
Gjest Slettet+142 Skrevet 23. oktober 2006 Del Skrevet 23. oktober 2006 har ikke så veldig peiling selv, men det ser ut som t du ikkje har tilgang til å enten bruke include() på filer utenom serveren... som du ser her: Warning: include(http://bettersaf.frac.dk/bettersafe/editor/phpnews_1-3-0/news.php) [function.include]: failed to open stream: Connection refused in /web/www/frac/users/b/bettersaf/bettersafe/Simple_Tabs/index.php on line 34 eller tar jeg feil nå? se om du finner noe info om include() ved å kjøre en liten phpinfo() Lenke til kommentar
Danielbv Skrevet 23. oktober 2006 Del Skrevet 23. oktober 2006 (endret) Hmm... Prøv å bruk: <?php include("./editor/phpnews_1-3-0/news.php"); ?> evt. <?php include("../editor/phpnews_1-3-0/news.php"); ?> Tror det er den øverste... Endret 23. oktober 2006 av djda9 Lenke til kommentar
Iris_L Skrevet 23. oktober 2006 Forfatter Del Skrevet 23. oktober 2006 Hmm...Prøv å bruk: <?php include("./editor/phpnews_1-3-0/news.php"); ?> evt. <?php include("../editor/phpnews_1-3-0/news.php"); ?> Tror det er den øverste... 7137016[/snapback] TAKK Det fungerte! (Nummer 2) Lenke til kommentar
Danielbv Skrevet 23. oktober 2006 Del Skrevet 23. oktober 2006 Aaahh Godt å kunne være til hjelp avogtil Lenke til kommentar
