Liten ini tweak til Gothic III
- ObjectDetails.fScreenObjectDistanceCulling_High=0. 008
- ObjectDetails.fProcessingRangeFadeOutRange_High=30 0.0
- ObjectDetails.fRangedBaseLoDOffset_High=300.0
Change the first value to 0.016
Change the second value to 600.0
Change the second value to 5000.0
Er det rett at den nederste skal være av den verdien? Ikke en "0" for mye altså?
(Ellers) Fin guide :thumbup:. Bra nok potensiale for en sticky synes jeg :).
Så en oppfølgingspost på akkurat denne: her http://forum.jowood.com/showpost.php?p=1879190&postcount=18
så kan være lurt å oppdatere første post her også med denne informasjonen, ellers så er jo dette en veldig god tråd:
http://forum.jowood.com/showthread.php?t=126976
Quote:
Originally Posted by impulse101 View Post
YOu made a mistake on this:
To increase item and object draw distance (on high details):
The higher you raise these the lower the draw distance is. You can tell by looking at the medium and low settings for this as by default their values are much higher than the high setting. SO the lower you make these values the better the draw distance.
The third one is definitely not wrong. But after some testing it seems that the first two don't have a big impact as I didn't notice much of a difference when they are doubled. But it didn't hurt my performance either.
Endret av krist2
Fra http://forum.jowood.com/showthread.php?t=126976&page=6
Btw ... I gained a lot IMHO by tweaking:
FpS.Average=25.0
FpS.Min=15.0
FpS.Max=40
The original max FPS that the game try to reach is 120 ... so by setting it to 40 you free up space and resources ... then raising min FPS from 10 to 15 makes it so the game dont even try to go under that (if I get what happened in my game) ... the average is what it try to maintain ....
But the biggest results is by raising the cach settings this way you got more things on the RAM and have less stutz when loading stuff.
Now I can run at something between mid and high details ... I switchedthe shadows off naturally.
Holder på å tester dette selv nå..
Noen som kan bekrefte om det funker?
Edit: Ved å senke FpS.Max til 40-50 merket jeg en liten økning på et par FPS.
Endret av Istapp
