Loading Java applet failed
Dessverre har ikke dere tilgang til siden som jeg får feilen på siden den er på vårt intranett.
Her er loggen fra Java Console:
Java Plug-in 1.5.0_06
Using JRE version 1.5.0_06 Java HotSpot Client VM
User home directory = C:\Documents and Settings\sfj
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
init createImage failed:
java.lang.IllegalArgumentException: Width (-15) and height (-40) cannot be <= 0
at java.awt.image.DirectColorModel.createCompatibleWritableRaster(Unknown Source)
at sun.awt.Win32GraphicsConfig.createAcceleratedImage(Unknown Source)
at sun.awt.windows.WComponentPeer.createImage(Unknown Source)
at java.awt.Component.createImage(Unknown Source)
at prediktor.tree.PTree.init(PTree.java:200)
at prediktor.tree.TreeScroll.init(TreeScroll.java:43)
at prediktor.tree.AppletTree.init(AppletTree.java:162)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
java.lang.IllegalArgumentException: Width (-15) and height (15) cannot be <= 0
at prediktor.tree.AppletTree.init(AppletTree.java:164)
java.util.MissingResourceException: Can't find bundle for base name sun.text.resources.LocaleElements, locale en_US
at java.util.ResourceBundle.throwMissingResourceException(Unknown Source)
at java.util.ResourceBundle.getBundleImpl(Unknown Source)
at java.util.ResourceBundle.getBundle(Unknown Source)
at prediktor.util.DecimalFormatSymbols.initialize(DecimalFormatSymbols.java:334)
at prediktor.util.DecimalFormatSymbols.<init>(DecimalFormatSymbols.java:68)
at prediktor.util.DecimalFormat.<init>(DecimalFormat.java:286)
at prediktor.trend.ValueDisplay.<init>(ValueDisplay.java:86)
at prediktor.trend.MainView.init(MainView.java:173)
at prediktor.trend.MainView.<init>(MainView.java:167)
at prediktor.trend.TrendViewer.addPlotArea(TrendViewer.java:190)
at prediktor.trend.TrendViewer.initTrendViewer(TrendViewer.java:182)
at prediktor.trend.TrendViewer.init(TrendViewer.java:136)
at prediktor.trend.TrendViewer.<init>(TrendViewer.java:91)
at prediktor.trend.TrendViewerApplet.init(TrendViewerApplet.java:751)
java.lang.NullPointerException
at prediktor.util.DecimalFormatSymbols.initialize(DecimalFormatSymbols.java:355)
Endret av mungo
Kanskje utviklerne hos prediktor kan svare?
Er det http://www.prediktor.no sitt produkt?
