Kurt_im Skrevet 14. oktober 2006 Del Skrevet 14. oktober 2006 Hellois Har dette scriptet, men det viser ikke bilde, kun den svarte firkantent?? Hvorfor det <?php # Constants define("IMAGE_BASE", '../images'); define("MAX_WIDTH", 50); define("MAX_HEIGHT", 50); # Get image location $image_file = str_replace('..', '', $_SERVER['QUERY_STRING']); $image_path = IMAGE_BASE . "/huhu.jpg"; # Load image $img = null; $ext = strtolower(end(explode('.', $image_path))); if ($ext == 'jpg' || $ext == 'jpeg') { $img = @imagecreatefromjpeg($image_path); } else if ($ext == 'png') { $img = @imagecreatefrompng($image_path); # Only if your version of GD includes GIF support } else if ($ext == 'gif') { $img = @imagecreatefrompng($image_path); } # If an image was successfully loaded, test the image for size if ($img) { # Get image size and scale ratio $width = imagesx($img); $height = imagesy($img); $scale = min(MAX_WIDTH/$width, MAX_HEIGHT/$height); # If the image is larger than the max shrink it if ($scale < 1) { $new_width = floor($scale*$width); $new_height = floor($scale*$height); # Create a new temporary image $tmp_img = imagecreatetruecolor($new_width, $new_height); # Copy and resize old image into new image imagecopyresized($tmp_img, $img, 0, 0, 0, 0, $new_width, $new_height, $width, $height); imagedestroy($img); $img = $tmp_img; } } # Create error image if necessary if (!$img) { $img = imagecreate(MAX_WIDTH, MAX_HEIGHT); imagecolorallocate($img,0,0,0); $c = imagecolorallocate($img,70,70,70); imageline($img,0,0,MAX_WIDTH,MAX_HEIGHT,$c2); imageline($img,MAX_WIDTH,0,0,MAX_HEIGHT,$c2); } # Display the image header("Content-type: image/jpeg"); imagejpeg($img); ?> Lenke til kommentar
Martin A. Skrevet 15. oktober 2006 Del Skrevet 15. oktober 2006 Fjern "@" fra @imagecreatefromjpeg($image_path) slik at du kanskje får en feilmelding. Lenke til kommentar
Gjest Slettet-rXRozPkg Skrevet 15. oktober 2006 Del Skrevet 15. oktober 2006 Du har også @imagecreatefrompng($image_path) under gif-delen, så det er ikke rart hvis du tester med gif bilder. Her skal det selvfølgelig brukes imagecreatefromgif. Lenke til kommentar
