Ikke menytekst i Titan Quest demo
  Sitat
(This may occur if you are installing the game on a Windows OS that is not in English)
Solution:
In the Titan Quest\Settings folder open the defaults.txt file and add or edit the line to read:
language = English
to the top of the file.
Also in My Documents\My Games\Titan Quest Demo\Settings edit the options.txt file with the same line:
language = English
and save that as well.
This should make the text appear in english and then you can manually change the language when you are in the game.
