Feit mod..
Quote:
Q: What about interference, static, electromagnetic radiation, magnetic fields, tachyon beams, or other bad mojo that could result if I install this in my PC?
A: You have to make decisions on your own about whether the risk is worth it. But consider that this is more or less the same principle used in a fluorescent lamp, it's just round and has some different gases inside it. There's high voltage AC from the inverter. You'll want to be careful that you don't connect that to anything metal in your case. I took extra care to have nonconductive pieces only in touch with the globe surface. You'll want to make sure your chassis is properly grounded (earthed), and verify the outlet you are using for power is properly grounded/earthed as well. I've had no indication that running this in my case is different that using a neon or fluorescent lamp.
Han skreiv hvertfall det han duden som gjorde dette lille prosjektet her. Hadde vært vannvittig morro og få til dette. Er det noen som vet hvor man kan få kjøpt sånne lamper? Over en nettbutikk eller noe hadde jo vært toppen!
Min bror har en slik lampe, jeg kjøpte den til han til jul for et par år siden (kostet vel 200 kr eller.no). Har lenge vurderet å stikke av med den etter at jeg begynte å modde, men har alltid lurt på om den var skadlig for diverse utstyr. Men siden det gikk greit så ser jeg en liten mulighet for at min bror ikke har den lampen serlig lenge :smile:
