Ubuntu 6.06, No direct redering!, Intel 945G
Hei!
Jeg klarer ikke å få til direct rendering, den ser ut til å ha driveren men direct rendering er altså ikke aktivert.
coderapor@coderapor-laptop:~$ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: No
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
   GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
   GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read,
   GLX_SGIS_multisample, GLX_SGIX_hyperpipe, GLX_SGIX_swap_barrier,
   GLX_SGIX_fbconfig
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
   GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
   GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
   GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
   GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
   GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
   GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
   GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
   GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
   GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.2 (1.5 Mesa 6.4.1)
OpenGL extensions:
   GL_ARB_depth_texture, GL_ARB_imaging, GL_ARB_multitexture,
   GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shadow,
   GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
   GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
   GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
   GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
   GL_ARB_texture_rectangle, GL_ARB_transpose_matrix, GL_ARB_window_pos,
   GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate,
   GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
   GL_EXT_clip_volume_hint, GL_EXT_copy_texture, GL_EXT_draw_range_elements,
   GL_EXT_fog_coord, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels,
   GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_rescale_normal,
   GL_EXT_secondary_color, GL_EXT_separate_specular_color,
   GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
   GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
   GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
   GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
   GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
   GL_EXT_vertex_array, GL_APPLE_packed_pixels, GL_ATI_texture_env_combine3,
   GL_ATI_texture_mirror_once, GL_ATIX_texture_env_combine3,
   GL_HP_occlusion_test, GL_IBM_texture_mirrored_repeat,
   GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
   GL_NV_blend_square, GL_NV_point_sprite, GL_NV_texgen_reflection,
   GL_NV_texture_rectangle, GL_SGIS_generate_mipmap,
   GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
   GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow,
   GL_SGIX_shadow_ambient, GL_SUN_multi_draw_arrays
  visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x23 24 tc  0 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x24 24 tc  0 24  0 r  y  .  8  8  8  0  0 16  8 16 16 16  0  0 0 None
0x25 24 tc  0 32  0 r  y  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x26 24 tc  0 32  0 r  .  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x27 24 dc  0 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  0 0 None
0x28 24 dc  0 24  0 r  y  .  8  8  8  0  0 16  8 16 16 16  0  0 0 None
0x29 24 dc  0 32  0 r  y  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
0x2a 24 dc  0 32  0 r  .  .  8  8  8  8  0 16  8 16 16 16 16  0 0 None
coderapor@coderapor-laptop:~$ glx info
Intel skal jo støttes fra før i Ubuntu, så hva må jeg gjøre for å fikse dette da?
Ny driver?
hm, helt fersk insall av Ubuntu Dapper på en IBM ThinkPad R52 her:
lars@ibmr52:~/programming/lisp/symbolicweb$ lspci | grep VGA
0000:00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 03)
lars@ibmr52:~/programming/lisp/symbolicweb$ glxinfo | grep direct
direct rendering: Yes
det kan hende 945 ikke er støttet ennå? - jeg vet ikke ..la merke til en annen forskjell:
lars@ibmr52:~/programming/lisp/symbolicweb$ glxinfo | grep vendor
OpenGL vendor string: Tungsten Graphics, Inc
..vendor-stringen matcher ikke din.. jeg tror jeg ville forsøkt å boote fra en Ubuntu Dapper live-CD og sjekke hva som skjer da
