Avspilling av x264.mkv-filer i Ubuntu(Dapper)
Ok, nå skjedde det noe.
MPlayer 2:0.99+1.0pre7try2+cvs20060117-0ubuntu8 © 2000-2006 MPlayer Team
CPU: Intel Pentium M Dothan (Family: 6, Stepping: 8)
CPUflags:  MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled with runtime CPU detection.
91 audio & 204 video codecs
Linux RTC init error in ioctl (rtc_irqp_set 1024): Permission denied
Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts.
Opening joystick device /dev/input/js0
Can't open joystick device /dev/input/js0: No such file or directory
Can't init input joystick
Setting up LIRC support...
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
Playing /home/*****/Desktop/*****
[mkv] Track ID 1: audio (A_AC3), -aid 0, -alang und
[mkv] Track ID 2: video (V_MPEG4/ISO/AVC), -vid 0
[mkv] Will play video track 2
[mkv] Will play audio track 1
Matroska file format detected.
VIDEO:  [avc1]  1280x720  24bpp  23.976 fps    0.0 kbps ( 0.0 kbyte/s)
Opening audio decoder: [liba52] AC3 decoding with liba52
Using SSE optimized IMDCT transform
AC3: 5.1 (3f+2r+lfe)  48000 Hz  448.0 kbit/s
Using MMX optimized resampler
AUDIO: 48000 Hz, 2 ch, s16le, 448.0 kbit/29.17% (ratio: 56000->192000)
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
Building audio filter chain for 48000Hz/2ch/s16le -> 0Hz/0ch/??...
alsa-init: 1 soundcard found, using: default
alsa: 48000 Hz/2 channels/4 bpf/65536 bytes buffer/Signed 16 bit Little Endian
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
Building audio filter chain for 48000Hz/2ch/s16le -> 48000Hz/2ch/s16le...
Starting playback...
VDec: vo config request - 1280 x 720 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO: [xv] 1280x720 => 1280x720 Planar YV12
aspect: Warning: no suitable new res found!
X11 error: BadAlloc (insufficient resources for operation)?,?% 1 0
MPlayer interrupted by signal 6 in module: vo_check_events
- MPlayer crashed. This shouldn't happen.
  It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
  gcc version. If you think it's MPlayer's fault, please read
  DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
  won't help unless you provide this information when reporting a possible bug.
Dere skjønner sikkert hvorfor det er stjerner der filnavnet skulle vært...
Ja, nå startet filen. Men som jeg trodde er denne PC'en for dårlig til å kjøre den type filer. Mulig jeg prøver det på den andre senere en gang.
Men hvordan skal jeg få Mplayer til å spille av denne filen uten å kjøre denne komandoen hver gang?
Har du drivere inne til skjermkortet ditt?
7047738[/snapback]
Nei, jeg har ikke gjort noe med det siden jeg installerte Ubuntu. Jeg har et Nvidia internt skjermkort. Men vet ikke om det har noe med det å gjøre. Den har bare 512 MB RAM, og Intel Celeron M 1,3 GHz prosessor.
