Rabbid Skrevet 8. oktober 2006 Del Skrevet 8. oktober 2006 Hvordan få denne til å virke i FireFox? Feilmeldingen er: "event is not defined" <script language="javascript"> <!-- /* Draggable objects Ver 1.1 (windows, frames, ...) ----------------------------------------------------------------------- This code shows how to create draggable objects, (like windows). Without remarks, the actual code is very small, yet effective. ----------------------------------------------------------------------- It uses only 3 function: drag_start(obj) - Just pass this function the object you want to drag, and dragging will start. drag_stop() - This function stops the dragging. drag_do() - This function actually performs the dragging. (It is attached to the document.onmousemove event. ----------------------------------------------------------------------- Code History: ------------- Ver 1.1: Notes & Remarks added. Ver 1.0: Initial publication ----------------------------------------------------------------------- (c) All rights reserved to Code Monk ... but you can have them... :) ----------------------------------------------------------------------- */ /*------ windows/frames drag functions & variables ------*/ var objDragMe = null; // object to drag var dx = 0, dy = 0; // delta-x, delta-y var z = 1; // z-index, used to make object topmost function drag_start(obj) { // stores the window/frame (div) object, dx & dy objDragMe = obj; dx = document.body.scrollLeft + event.clientX - objDragMe.style.pixelLeft; dy = document.body.scrollTop + event.clientY - objDragMe.style.pixelTop; // puts window on top of all other windows objDragMe.style.zIndex = z++; // starts dragging... document.onmousemove = drag_do; } function drag_stop() { // stops dragging document.onmousemove = ""; } function drag_do() { // checks if mouse is still pressed. // (this was added to fix a bug when leaving the broswer window // with the mouse pressed then returning without pressing it.) if (event.button != 1) { drag_stop(); return; } // moves object objDragMe.style.pixelLeft = document.body.scrollLeft + event.clientX - dx; objDragMe.style.pixelTop = document.body.scrollTop + event.clientY - dy; // disables text selection document.selection.empty(); } //--> </script> mvh. Hans Lenke til kommentar
Kagee Skrevet 24. oktober 2006 Del Skrevet 24. oktober 2006 (endret) Du bruker et script som er crossbrowser. Som dette: http://dunnbypaul.net/js_mouse/ Funker i IE og Opera, da regner jeg med at det funker i FF også. Hvis du ikke er fornøyd med denne, se her: http://www.google.com/search?q=Draggable+o...irefox+ie+opera Endret 24. oktober 2006 av Kagee Lenke til kommentar
