Straffa Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 (endret) TOKYO (MarketWatch) -- Sony Corp. (6758.TO) said Tuesday it heard that its PlayStation 3 on exhibit at last month's Tokyo Game Show might have encountered some trouble, fanning concerns about its crucial next-generation game machine.The Japanese electronics company has already been plagued by difficulties in manufacturing a key component for the PS3, which forced it last month to delay the European launch of the game console by four months, missing the all-important year-end shopping season in one of its major markets. "We heard that some trouble happened at TGS but haven't identified what happened. Therefore, we don't know exactly if it really happened or not and what the cause was," said a spokesman for Sony Computer Entertainment Inc. Asked if Sony was investigating the issue, he said: "I don't think so." He declined to comment when asked if the PS3s on exhibit at the Tokyo Game Show had to be reset often. Sony's shares were down 2.7% at Y4,600 at midday, after hitting a low of Y4,580 in earlier trading on the Tokyo Stock Exchange. The spokesman was responding to a report issued Monday by Macquarie analyst David Gibson, who wrote that concerns about possible stability problems in the PlayStation 3 are likely to weigh on Sony's shares in the short term. "We have heard that at the TGS PS3s had stability problems and had to be reset often. While the reason for this is unknown we suspect it may be due to overheating as a result of enclosing the units and the high temperatures at the venue. We understand that Sony is investigating the issue and has not determined the cause as yet," Gibson wrote. "We are concerned that such a problem has occurred so close to full production (end-Sept) and is clearly negative news for the company," he wrote. A spokesman for Sony Corp. said the Japanese company hadn't changed its plans to ship 6 million PS3 machines globally by March 2007. Gibson wrote he was keeping his "outperform" rating on Sony's stock, saying Macquarie still believes that the company's electronics division is turning around and that "PS3 issues can be addressed in time for the launch." Link Endret 3. oktober 2006 av avanore Lenke til kommentar
Mr.FOXHOUND Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Blir nok en del trøbbel med første bermen av konsoller denne gangen også ja. Lenke til kommentar
Straffa Skrevet 3. oktober 2006 Forfatter Del Skrevet 3. oktober 2006 Blir nok en del trøbbel med første bermen av konsoller denne gangen også ja. 6991397[/snapback] Kanskje en fordel at Europa ikke får den før i Mars så de får luket ut feilene Lenke til kommentar
Mr.FOXHOUND Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Blir nok en del trøbbel med første bermen av konsoller denne gangen også ja. 6991397[/snapback] Kanskje en fordel at Europa ikke får den før i Mars så de får luket ut feilene 6991416[/snapback] Spørs hvor mye luking det blir, og hvor mye de må stresse for å få lagt til side Eurokonsollene, samtidig som de dekker Japan og USA da.. Men kjipest blir det for europeere som forhåndsbestiller fra USA, og får en defekt konsoll. Ser for meg et helvete med tanke på garanti o.l. i en slik situasjon Lenke til kommentar
Bromlexl Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 at det var varmeproblemer under TGS kan jo ha flere årsaker. De er kanskje ikke perfekt produsert enda. Det skal nok sies. de første ut av fabrikken er vel skjeldent de beste. Det var nok også temmelig varmt inne på showet. Noe som nok gjorde at de ble litt varmere en de vil bli i kalde norge. "all hail cold fuckin norway" Blir spennende og se dette ja. Og angående importering av PS3 så er kanskje ikke det så lurt siden du da har INGEN garanti. Noe jeg vil ha på en såpass dyr konsoll. PSP var greit nok siden den var SYKT utsatt. Lenke til kommentar
Swoofah Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 1) plasser 1 stk konsoll i en lukket plastboks med minimal, men "nok", lufting. 2) plasser tusner av mennesker i samme rom/hall som boksen. 3) La den stå å gå i evigheter. 4) Legg til ligningen at temperaturen i rommet/hallen er bra høy fra før. Hehe, jeg er ikke overrasket over at de hadde temp. problemer på TGS, OM det var det som var årsaken. Bildet med en vifte rettet mot en PS3 har jo sirkulert litt Jeg er faktisk mer overrasket over at dette ikke skjer oftere Lenke til kommentar
Swoofah Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Jaja, den dagen DET skjer, så skal jeg ihvertfall være sinna på sony i et par dager.. djiz Lenke til kommentar
Mala Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Ingen her inne bør vere overrasket om det dukker opp varmeproblemer på PS3. Med den snacksen av hardware og i tillegg til integrert PSU i boksen så blir det varmt altså. Lenke til kommentar
deltamannen Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Og angående importering av PS3 så er kanskje ikke det så lurt siden du da har INGEN garanti. trodde Sony hadde verdensomspennende garanti. slik var det hvertfall da jeg fiksa minidisc'en som jeg kjøpte i hong kong. leverte den på elkjøp, og de fiksa den. Lenke til kommentar
Bromlexl Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Og angående importering av PS3 så er kanskje ikke det så lurt siden du da har INGEN garanti. trodde Sony hadde verdensomspennende garanti. slik var det hvertfall da jeg fiksa minidisc'en som jeg kjøpte i hong kong. leverte den på elkjøp, og de fiksa den. 6992344[/snapback] jeg kan ha tatt feil, men husker det var en av faresonene som man gikk gjennom når man importerte PSPer. Men det var ingen feil på den så no harm done. Bør ivertfall sjekke ut det før man kjøper, og de fikser den kanskje ikke før den er lansert og et system for defekte konsoller er satt i verk i vår verdensdel. Lenke til kommentar
Straffa Skrevet 3. oktober 2006 Forfatter Del Skrevet 3. oktober 2006 (endret) 3) La den stå å gå i evigheter. 6991937[/snapback] Det som var problemet Endret 3. oktober 2006 av avanore Lenke til kommentar
MindTooth Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Vil faktisk tro at faktisk Sony har brukt litt mere tid på å feilsøke evt. varmeproblemer. Da vi merket veldig godt med X360 at den ble dugelig varm. Tror ikke de vil oppleve det samme. Birger Lenke til kommentar
Mala Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Vil faktisk tro at faktisk Sony har brukt litt mere tid på å feilsøke evt. varmeproblemer. Da vi merket veldig godt med X360 at den ble dugelig varm. Tror ikke de vil oppleve det samme. Birger 6993576[/snapback] Ja de må ha noen saklig heftige ribber på innsiden av konsollen i og med at den er nesten heilt stille (siest det). Men om folk stuer den vekk i det trange tar den nok kvelden kjappt slik som 360`en. Lenke til kommentar
Nonsens Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Nå er det jo rimelig varmt på slike messer da; de fleste stuer er vel ikke i nærheten av den varmen man får i en fullstappet messehall. Men at det vil blir problemer med en del av PS3ene ved lanseringen er vel noe en må regne med; å lansere et produkt med mye ny teknologi i slikt volum uten at det er feil på en del av dem har vel aldri skjedd før og skjer neppe denne gangen heller. Lenke til kommentar
MindTooth Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Selvfølgelig er det noe å tenke over da man har kjøpt seg en PS3. Uansett vil jeg tro Sony har jobbet mere en Microsoft på dette området. Birger Lenke til kommentar
The Stig Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Skal sies til Sonys forsvar at jeg aldri har verken opplevd eller hørt om noe problemer på sine PS2 konsoller. Jeg kjøpte en av de aller første som kom, og så sent som nå i skolesommerferien ble den glemt påslått i 3 uker. Kom tilbake og fortsatte spilleøkten fra der jeg slapp Lenke til kommentar
Avean Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 (endret) Ikke jeg heller . Eide 6 ulike serier av Playstation 1 og har hatt 2 PS2 konsoller uten noe problemer. Kjenner ingen som har hatt noe problem heller selv om de har vært chippa til døds også. Sony kan å lage stabile maskiner. Endret 3. oktober 2006 av Avean Lenke til kommentar
phewBAR Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 (endret) Ikke jeg heller . Eide 6 ulike serier av Playstation 1 og har hatt 2 PS2 konsoller uten noe problemer. Kjenner ingen som har hatt noe problem heller selv om de har vært chippa til døds også. Sony kan å lage stabile maskiner. 6994110[/snapback] Hva hadde du 6 ulike PSX maskiner om man får spørre? Selv har jeg hatt 2stk PS2, og en tok kvelden.. den andre tok til slutt bare skiver som var av fargen lilla på undersiden.. Endret 3. oktober 2006 av Drunk In Public Lenke til kommentar
freke Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 Ikke jeg heller . Eide 6 ulike serier av Playstation 1 og har hatt 2 PS2 konsoller uten noe problemer. Kjenner ingen som har hatt noe problem heller selv om de har vært chippa til døds også. Sony kan å lage stabile maskiner. 6994110[/snapback] Jeg har mer "strul" med ps2 enn med 360 personlig. Titt og ofte vil ikke ps2 lese platene og jeg må mikke og dalle med den for å få det til. Enda ikke hatt pes med 360 da. Lenke til kommentar
The Stig Skrevet 3. oktober 2006 Del Skrevet 3. oktober 2006 (endret) Ikke jeg heller . Eide 6 ulike serier av Playstation 1 og har hatt 2 PS2 konsoller uten noe problemer. Kjenner ingen som har hatt noe problem heller selv om de har vært chippa til døds også. Sony kan å lage stabile maskiner. 6994110[/snapback] Jeg har mer "strul" med ps2 enn med 360 personlig. Titt og ofte vil ikke ps2 lese platene og jeg må mikke og dalle med den for å få det til. Enda ikke hatt pes med 360 da. 6994200[/snapback] Så snodig, at en knapt halvt år gammel konsoll virker bedre en eldgammel konkurrent, som i tillegg - etter all sannsynlighet - skal lese av ripete plater. Nuvel, hater at jeg skriver innlegg som det der - men det der ble for dumt. Endret 3. oktober 2006 av Stikk-kont@kten Lenke til kommentar
