Program til å måle temperaturer?
Her har du det du leter etter: SpeedFan! :D
SpeedFan is a freeware program that monitors voltages, fan speeds and temperatures  in computers with hardware monitor chips. (...) At the lowest level, SpeedFan is an hardware monitor software that can access digital temperature sensors, but its main feature is that it can change fan speeds  (depending on the capabilities of your sensor chip and your hardware) according to the temperatures inside your pc, thus reducing noise.
