Støtter "XFX GeForce 7900GS" SLI? Or not?
Marti
Jeg leste litt på SLIZone, og fikk med meg at 7900GS kortet til nVidia ikke støttet SLI. Dvs, kort som 6800 ultra, 7800GT, 7600GT osv støttet SLI, men 7900GS ble ikke nevnt. Er dette en feil eller støtter faktisk ikke GS kortet SLI? Virker veldig rart egentlig. Hvis noen vet, vær så vennlige :).
Hugs and kisses.
Designed for extreme HD gaming, the NVIDIA® SLI™-Ready GeForce® 7900 graphics processing units (GPUs) deliver the most graphics performance bang for your buck, including ultra-realistic gaming experiences and resolutions up to 2560x1600. A 256-bit memory interface and fast GDDR3 memory enable blazing graphics performance with maximum quality so you don’t have to choose between frame rates and image quality.
Need a break from gaming? The GeForce 7900 GPU also delivers smooth, high-definition video playback and crisp picture quality thanks to its advanced NVIDIA® PureVideo™ technology.
If you are searching for an extreme HD gaming and video experience on the PC, look no further than a GeForce 7900 GPU.
Available Models: GeForce 7900 GTX, GeForce 7900 GT, and 7900 GS
Les mer her
Endret av Scortech
