Disk må formateres etter reinstall.
Kvammis
_______/ MBRlister version 1.1 \______
------------------------------------------------------->> Disk 0 MBR
# Activeflag Offset _____Size____________ Type
1 80 = Yes 63 488375937 = 238464 GB 07 = Windows NT NTFS
2 00 = No 0 0 = 0 GB 00 = Empty
3 00 = No 0 0 = 0 GB 00 = Empty
4 00 = No 0 0 = 0 GB 00 = Empty
>> Disk 0 Partition Boot sector (sector 64)
000: eb 52 90 4e 54 46 53 20 20 20 20 00 02 08 00 00 .R.NTFS .....
010: 00 00 00 00 00 f8 00 00 3f 00 ff 00 3f 00 00 00 ........?...?...
020: 00 00 00 00 80 00 80 00 80 06 1c 1d 00 00 00 00 ................
030: 00 00 0c 00 00 00 00 00 68 c0 d1 01 00 00 00 00 ........h.......
040: f6 00 00 00 01 00 00 00 14 c3 a8 7c d8 a8 7c c8 ...........|..|.
050: 00 00 00 00 fa 33 c0 8e d0 bc 00 7c fb b8 c0 07 .....3.....|....
060: 8e d8 e8 16 00 b8 00 0d 8e c0 33 db c6 06 0e 00 ..........3.....
070: 10 e8 53 00 68 00 0d 68 6a 02 cb 8a 16 24 00 b4 ..S.h..hj....$..
080: 08 cd 13 73 05 b9 ff ff 8a f1 66 0f b6 c6 40 66 ...s......f...@f
090: 0f b6 d1 80 e2 3f f7 e2 86 cd c0 ed 06 41 66 0f .....?.......Af.
0a0: b7 c9 66 f7 e1 66 a3 20 00 c3 b4 41 bb aa 55 8a ..f..f. ...A..U.
0b0: 16 24 00 cd 13 72 0f 81 fb 55 aa 75 09 f6 c1 01 .$...r...U.u....
0c0: 74 04 fe 06 14 00 c3 66 60 1e 06 66 a1 10 00 66 t......f`..f...f
0d0: 03 06 1c 00 66 3b 06 20 00 0f 82 3a 00 1e 66 6a ....f;. ...:..fj
0e0: 00 66 50 06 53 66 68 10 00 01 00 80 3e 14 00 00 .fP.Sfh.....>...
0f0: 0f 85 0c 00 e8 b3 ff 80 3e 14 00 00 0f 84 61 00 ........>.....a.
100: b4 42 8a 16 24 00 16 1f 8b f4 cd 13 66 58 5b 07 .B..$.......fX[.
110: 66 58 66 58 1f eb 2d 66 33 d2 66 0f b7 0e 18 00 fXfX..-f3.f.....
120: 66 f7 f1 fe c2 8a ca 66 8b d0 66 c1 ea 10 f7 36 f......f..f....6
130: 1a 00 86 d6 8a 16 24 00 8a e8 c0 e4 06 0a cc b8 ......$.........
140: 01 02 cd 13 0f 82 19 00 8c c0 05 20 00 8e c0 66 ........... ...f
150: ff 06 10 00 ff 0e 0e 00 0f 85 6f ff 07 1f 66 61 ..........o...fa
160: c3 a0 f8 01 e8 09 00 a0 fb 01 e8 03 00 fb eb fe ................
170: b4 01 8b f0 ac 3c 00 74 09 b4 0e bb 07 00 cd 10 .....<.t........
180: eb f2 c3 0d 0a 4c 65 73 65 66 65 69 6c 20 70 86 .....Lesefeil p.
190: 20 64 69 73 6b 65 6e 00 0d 0a 4e 54 4c 44 52 20 disken...NTLDR
1a0: 6d 61 6e 67 6c 65 72 00 0d 0a 4e 54 4c 44 52 20 mangler...NTLDR
1b0: 65 72 20 6b 6f 6d 70 72 69 6d 65 72 74 00 0d 0a er komprimert...
1c0: 54 72 79 6b 6b 20 43 74 72 6c 2b 41 6c 74 2b 44 Trykk Ctrl+Alt+D
1d0: 45 4c 20 66 6f 72 20 86 20 73 74 61 72 74 65 20 EL for . starte
1e0: 70 86 20 6e 79 74 74 0d 0a 00 00 00 00 00 00 00 p. nytt.........
1f0: 00 00 00 00 00 00 00 00 83 98 a8 be 00 00 55 aa ..............U.
>> Disk 0 BPB decoded:
OEM ID : NTFS
Number of bytes per sector : 512
Number of sectors per cluster : 8
Number of sectors in reserved area : 0
Media descriptor : f8
Number of sectors per track : 63
Number of heads (sides) : 255
Number of hidden sectors : 63
Total Sectors : 488375936
Logical Cluster Number for the file $MFT : 786432
Logical Cluster Number for the file $MFTMirr : 30523496
Clusters Per File Record Segment : 246
Clusters Per Index Block : 1
Volume serial number : C87CA8D87CA8C314
------------------------------------------------------->> Disk 1 MBR
1 00 = No 63 488375937 = 238464 GB 07 = Windows NT NTFS
>> Disk 1 Partition Boot sector (sector 64)
000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
1f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
>> Disk 1 BPB decoded:
Sector is all zeroes.
Det var det jeg mente om 000000000.
Det er ikke noe feil at det er null og derfor Windows vil formatere.
Men hvor ble det med det som var der før, eller hvorfor er borte er vanskelig å si.
Men det som er jeg sikker på, er at kopien av det som var der finnes på en bestemt sector på disken din og du må hente det tilbake.
Bootsector er så viktig at den blir automatisk kopiert i NTFS file system.
For å gjøre det du må finne deg en editor. Du trenger mer en bare å lese. Du skal jobbe med det.
Du sier at du finner ikke dskprobe. Det er i support.cab i din Windows CD.
Har du ikke CD eller? Da laste ned support tools fra Microsoft sine sider og installere alt sammen. Da vil den være der når du trenger det.
Så enkelt er det.
Har hatt mer eller mindre prob selv.. fant ingen feil på disken og fikk ikke noen "fikse" program til å finne tilbake til filene..
Jeg tok ut disken, installerte windows på nytt og da plutselig fant den alt sammen.. ALT var der.. skjønner til dags dato ikke noen som helst ting av det hele
Var borti det samme. Jeg bootet på xp-plata, valgte recovery, og kjørte fixmbr på den disken / partisjonen som var ødelagt. Det ordnet allt til meg..
7093045[/snapback]
Det vil nok ikke hjelpe her. Det er ikke noe problem med MBR, så det var ikke samme problem du hadde.
Jeg har nevnt FIXBOOT før i denne tråden, og det burde fikse problemet hvis kopien er OK.
wiberos: du tenker å gjøre dette manuellt, tror du ikke FIXBOOT skal virke?
Tror forresten du har helt rett at det skal hete sektor 63, jeg har vel blandet CHS og LBA tellemåte.
Det store spørsmålet her er dog hvorfor bootsektor er nullet ut. Vi får se om det dukker opp flere slike tilfeller og se om dette går igjen.
7093045[/snapback]
7094486[/snapback]
Jeg leste 2 ganger for å være sikker på det hårek, og det er det, at faktisk han har ikke brukt FiXboot enda. For at den skal fikse bootsectoren.
Så det har vært litt unødvendig mass på han det godt.
Men ellers tror jeg at det er noe med bios og kontrolleren som kan forårsake noe slik. Men er usikker.
Når det gjelder sectorene, det er riktig at vi teller fra 1, men Start og ending field og de verdiene der er fra 0.
Det var riktig resultat jeg fikk fra lister, det var bare det med 64, hvis vi skulle legge tilbake boot sectoren, da hadde vi feilet.
Så nå vi må få Kvammis til å bruke WRC og Fixboot, før han kaster heile greie ut av vinduet.
Med den probe vi bruker (Reletive+Total)-1 og kontrollere at det er riktig for så å skrive tilbake til 63. (hvis det var noe der da.)
Men jeg svarer allikevel når det gjelder Dskprobe så lenge han har installert den.
Jeg har nå laget enda en versjon av det programmet. Det sporer opp backup bootsektor og lister den.
Kan du forsøke denne Kvammis, så vet vi om Fixboot kan utrette noe.
Filen ligger på samme sted som sist.
Edit: Var visst litt for kjapp der. Det vil jo ikke fungere når BPB er nullet.
Må tenke litt på den.
Edit2: nå fikk jeg fikset det. Tok offset fra MBR i stedet.
Endret av hårek
Nå har jeg fått installert support tools og dskprobe.
Men vet ikke hvordan jeg bruker det. :)
7096281[/snapback]
Ja, det har vært litt for mye på deg nå, så jeg håper at det blir positiv resultat.
Det er Fixboot som skal ordne bootsectoren.
For å bruke fixboot, må du starte Pc-en fra Win CD-en, som om du skal installere Windows.
Etter at det er lastet en del får du spørsmål om å Installere Windows eller reparere.
Du taster E og Enter. Du må velge Windows installasjon, hos deg er å taste 1.
Du bare taster Enter når du får spørsmål om passord. Har du passord så skriver du det.
Nå må du kontrollere hvilken bokstav har disken du skal fikse.
Med å skrive map og tast Enter får opp diskene dine.
Du må ha væra obs, på at hvis du hadde mange disker og partisjoner, de bokstavene du hadde i diskbehandlingen er ikke alltid de samme fra den siden av verden.
Etter at du bekrefter bokstaven som gjelder kan du skrive fixboot E: eller F: eller den bokstav det gjelder.
Thats it. Du får meldning om det var i orden eller ikke. Skrive exit og tast Enter.
Nå til Dskprobe.
Dobbelklikk for å åpne den.
Fra drivers velg Physical Drive. I det vinduet som kommer, i rulle felten, dobbelklikk på Physical drive1. Klikk deretter på Set Active og klikk OK.
Klikk på Sectors og Read.
Der som står Starting sector skriver du 488376999 og klikk read.
Nå skal du klare å se noe som likner veldig mye på det som du hadde på din post 21 men dog for C: disken din.
Hvis det er tilfelle klikk på sectors igjen og velg Write.
Nå skriver du der som står det Starting sector 63. Dvs at du fjerner det som er allerede skrevet der. Det skal stå kun 63. Du får advarsel om du skal skrive, og du bare svarer Ja.
Nå kan du starte Pc-en på nytt. ( i mellomtiden springer jeg og hårek til skogs, hvis det går ikke bra.
Men for at vi skal kontrollere at sector tall osv er riktig, jeg har brukt de fra Hårek til nå, før du utfører det som står ovenfor skal du starte dskprobe og klikk på physical drive som beskrevet , set active, Ok. Nå velger du View og Partition table. Hvis det er ikke noe tall der, klikk next partition.
De tallene som er nederst på venstre og til høyre.
Det er de tallene som gjelder. Da skal du Summere Total sectors + relative. Fra det skal du trekke -1. Hvis summen blrir 488376999 kan du utfore første delen.
Hvis ikke, det er tallet som du har kommet fra som skal gjelde. Resten blir det samme.
uansett hvor mye du feiler når du bruker det , er det bare å avslutte og starte på nytt.
Det var det.
7100098[/snapback]
Det stemmer. Nå kan man sove godt ja.
Skal prøve de tingene som står over her nå. Lese gjennom det et par ganger til først bare :p
Kjørte den nye versjonen av programmet nå. skjønner som vanlig ingenting av hva det betyr tho :) hehe
Fikk feilmelding når jeg kjørte programmet, men den opprettet en fil likevel. Så limer bare inn det som sto i den:
_______/ MBRlister version 1.2 \______
>> Disk 0 Partition Boot sector (sector 63)
>> Disk 0 BPB decoded:
OEM ID : NTFS
>> Disk 0 Backup Boot sector (sector 488375999)
>> Disk 0 BPB decoded:
OEM ID : NTFS
>> Disk 1 Partition Boot sector (sector 63)
110: 0
kjørte fixboot nå og har tilgang til disken igjen :)
TUSEN TAKK for hjelpen folkens :D
Derimot har 135gb (det viktigste jeg hadde på disken) blitt mystisk borte :( Tenkte jeg skulle prøve å kjøre "easyrecovery" nå.. hehe
Endret av Kvammis
Det var ikke bra det.
Det stemmer ikke med sectorene gitt. Nå er jeg i hvertfall sikker om hvorfor det ble slik in the first place.
Ikke forandre noe, men dog du kan kontrollere at det finnes en bootsector på
på sector 488375999 med å bruke probe. Da skal du klikk på file og save as.
Da har du en kopi av den.
Så kan du åpne probe igjen, set active og alt dette der og velg read. Nå skal du lese sector 63. Klikk file og save as. Du kan da sammenligne de to filene.
Det var en partition du hadde før du fikk problemer eller?
Er det noe forandring på disken når du ser i diskbehandling? Er det noe ledig plass ? Se etter. Er det noe feilmeldninger? Er det detaljer om hvordan var disken før du fikk problemer? som kan være relevant her.
Sorry Kvammis men Fixboot ble til Nixboot.
Men i hvertfall,det må bli slik at man skal dobbelt kontrollere før man utfører en kommando. Det betyr ikke her at det er Fixboot som sviktet, men i hastverk glemte vi å kontrollere.
Det kan ordnes seg allikevel, og det er så fint at du har humør i behold.
Se det, nattskiftet har ordnet opp. :)
Vet ikke hvorfor programmet feilet, men det har jo ikke mye feilhåndtering (det er det vanskeligste ved å lage skikkelige program).
Uansett betyr det ingenting siden FIXBOOT virket.
7101921[/snapback]
Hva mener du med at det ikke stemmer? Det er to like disker, MBR er lik på begge, og programmet mitt fant backup på sektor 488375999 på disk 1.
Og siden FIXBOOT tydeligvis fant en OK backup på disk 2 så er det vel ikke mer å styre med.
7101921[/snapback]
7102296[/snapback]
Derimot har 135gb (det viktigste jeg hadde på disken) blitt mystisk borte  Tenkte jeg skulle prøve å kjøre "easyrecovery" nå.. hehe
Når han mangler 135GB av det viktiste han hadde etter Fixboot, jeg kan ikke se at det ble gode resulteter her. Det ble skrevet en ny oppstartssector, thats it.
(jeg sitter med flerre spørsmål som jeg kan ikke svare nå, enn før)
At Lister sviktet å vise resultet hos han, se post nr33(men det var Ok hos meg) beviser vel at det var grunn til å undersøke mer.
Vi sier stadig vekk at feilmeldninger er viktig detalj.
I det tilfelle her, fikk man jo en feilmeldning. Uten å undresøke videre utførte Fixboot.
Mitt poeng er følgende: En feilmeldning er ikke ensidig hendelse, og hvis man ikke prøver å dobbeltkontrollere i det minste, er bare å akseptere utfallet.
Hvis man skal styre utfallet, må til med andre fremgangsmåter en det vi presterte her.
Og hvis man skal ikke styre mer ned slike tilfeller, faller vel bort helle poenget med recovery? gjør ikke det da?
Så helst se positiv på det at lister nektet å printout resultater hårek. (lister, nektet ikke hos meg).
OK, jeg misoppfattet kanskje hva du mente først. Trodde du mente at nummereringen ikke stemmer.
Jeg ser ikke noen sammenheng mellom at MBRLister feilet på #33 og at han mangler 135GB. Det kan se ut som det feilet på en plass som tidligere har blitt lest (post #21). Programmet mitt leser bare sektorer, det vet ingenting om filsystemet.
Jeg tror heller det har skjedd noe med filsystemet i tillegg til at bootsektor ble slettet. Men hva det er blir bare gjetning.
Hvis du får anledning til det , kjøre lister 1.1 og 1.2. ta kopi av det printout og vedlegge her.
Du trenger ikke å vedlegge det som er for Disk 0, bare for disk 1, så cut og lim og vedlegge.
spørsmål: hadde du en partition fra opprinnelig eller var det en partisjon som du hadde merget med en annen eller noe sånt ? har altid vært full storm på den?
se om info på sector 244188031, 244188030, 244188029,244188032, 244188033 er noe alla den du har på sector 63 , og på sector 488375999.
Vi fikk liksom aldri bekreftet det. Hva står det på 488375999.
