Hva er et chipset ?
abs
Chipset er et sett (en gruppe) brikker som sammen gir fuksjonalitet til et "device"/produkt. Vanligvis i PC-verden består et hovedkorts chipset av en norbru og en sørbru (NB/SB) hvor nordbru tar seg av de tingene med veldig høy båndbredde og krav på latency som CPU-link, AGP, RAM og CSA-lan mens sørbrua tar seg av de lavere som USB, IEEE1394, PCI, PCIe, lydkontroller, Tbase 100 NIC og slikt.
Endret av JohndoeMAKT
What is chipset?
Chipset is the generical name given to the set of circuits used by the motherboard. Normally the chipset uses two circuits, called north bridge and south bridge. There are many chipsets manufacturers, like Intel, VIA, SiS and ALi. The motherboard's quality and performance is directly proportional to the chipset's quality.
The chipset is the heart of the computer. It determines how fast components like processor, memory, and plug-ins can function. Select a chipset that will maximize the potential and be compatible with other computer components.
( http://bugclub.org/beginners/hardware/chipset.html )
The system chipset and controllers are the logic circuits that are the intelligence of the motherboard. They are the "traffic cops" of the computer, controlling data transfers between the processor, cache, system buses, peripherals--basically everything inside the computer. Since data flow is such a critical issue in the operation and performance of so many parts of the computer, the chipset is one of the few components that have a truly major impact on your PC's quality, feature set, and speed.
( http://www.pcguide.com/ref/mbsys/chip/index.htm )
