Nemiz Skrevet 24. september 2006 Del Skrevet 24. september 2006 Hei. Har hatt samme PCen i et år nå uten å oppleve noe som helst problem. For et par dager siden begynte derimot maskinen å oppføre seg merkelig. Satt og spilte WoW, og plutselig gikk skjermen i stand by modus. Trykket på reset knappen, bootet inn i Windows igjen og fortsatte å spille uten å tenke mere over saken. Skjermen fortsatte å gå over i stand by modus under spilling ved jevne mellomrom. Etter siste reset fikk jeg opp følgende BSOD ved innlasting av Windows: "A problem has been detected and windows has been shut down to prevent damage to your computer. The problem seems to be caused by the following file: nv4_disp If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The device driver got stuck in an infinite loop. This usually indicates a problem with the device itself or with the device driver programming the hardware incorrectly. Please check with your hardware device vendor for any driver updates. Technical information: *** STOP: 0x000000EA(0x861B4F8,0x84F5E3F0,0x86205FB8,0x00000001) nv4_disp Beginning dump of physical memory Physical memory dump complete Contact your system administrator or technical support group for further assistance." Bootet deretter inn i Windows via sikker modus og fikk opp følgende feilmelding: "Computer restarted after an unexpected shutdown. Microsoft Windows detected a possible device failure. The driver for the display device was unable to complete a drawing operation. Please check with the device manufacturer for a driver update. Please tell Microsoft about this problem. The display driver for NVIDIA GeForce 6600 GT seems to be responsible for the system instability. Error signature szAppName : Drivers.Display szAppVer : 10DE0140A22005107D szModName : nv4_disp.dll szModVer : 6.14.10.6631" Prøvde å installere de nyeste driverne til nVIDIA, uten at det løste problemet med blåskjermen. Formaterte harddisken og la inn Windows XP på nytt igjen og fikk lastet inn Windows med default gfx driver. Prøvde deretter både å installere originaldriverne som fulgte med skjermkortet og de nyeste driverne, men fikk da samme BSOD. Ved avinstallering av driverne i sikker modus kommer jeg igjen inn i Windows med oppløsning 640x480 4bit, men det er umulig å forandre instillingene. Lurer på om skjermkortet har tatt kvelden eller hva som kan være galt. Her er spesifikasjonene fra Everest: Maskinnavn: Operativsystem Microsoft Windows XP Professional Operativsystem Service Pack Service Pack 1 DirectX 4.08.01.0810 (DirectX 8.1) Hovedkort: CPU type AMD Athlon 64, 1800 MHz (9 x 200) 3000+ Hovedkort Asus A8N-SLI (3 PCI, 2 PCI-E x1, 2 PCI-E x16, 4 DDR DIMM, Audio, Gigabit LAN) Hovedkort chipset nVIDIA nForce4 SLI, AMD Hammer System minne 1024 Mb (PC3200 DDR SDRAM) BIOS type Award (11/30/04) Kommuniksjons port Communications Port (COM1) Kommuniksjons port ECP Printer Port (LPT1) Skjerm: Skjermkort nVIDIA GeForce 6600 GT PCI-E (Leadtek WinFast PX6600 GT) 3D kort nVIDIA GeForce 6600 GT PCI-E Skjerm NEC 2080UX+ Multimedia: Lydkort nVIDIA MCP04 - Audio Codec Interface Lagring: IDE kontroller NVIDIA CK804 ADMA Controller (v2.7) IDE kontroller NVIDIA CK804 ADMA Controller (v2.7) IDE kontroller NVIDIA CK804 Parallel ATA Controller (v2.7) Diskett stasjon Floppy disk drive Harddisk WDC WD800BB-32CCB0 (74 Gb, IDE) Harddisk WDC WD600BB-00BSA0 (55 Gb, IDE) Optisk disk PIONEER DVD-RW DVR-105 (DVD:4x/2x/12x, CD:16x/8x/32x DVD-RW) SMART Harddisk status OK Nettverk: Nettverkskort NVIDIA nForce Networking Controller - Packet Scheduler Miniport Nettverkskort SMCWPCIT-G 108 Mbps Wireless PCI Adapter Prosessor egenskaper: Produsent AMD Versjon AMD Athlon 64 Processor 3000+ Ekstern klokkehastighet 200 MHz Maksimum klokkehastighet 3700 MHz Gjeldene klokkehastighet 1800 MHz Type Central Processor Spenning 1.5 V Status På Sokkel utforming Socket 939 CPU egenskaper: CPU type AMD Athlon 64 3000+ Prosessor alias Winchester S939 CPU stepping DH-D0 CPUID CPU navn AMD Athlon 64 Processor 3000+ CPUID revisjon 00010FF0h CPU hastighet: CPU klokkehastighet 1809.06 MHz CPU multiplier 9.0x CPU FSB 201.01 MHz (orginal: 200 MHz) Minne buss 201.01 MHz CPU chache: L1 kode hurtigbuffer 64 Kb (Parity) L1 data hurtigbuffer 64 Kb (ECC) L2 hurtigbuffer 512 Kb (On-Die, ECC, Full-Speed) Hovedkort egenskaper: Hovedkort ID 11/30/2004-NF-CK804-A8NSLI-B-00 Hovedkort Asus A8N-SLI (3 PCI, 2 PCI-E x1, 2 PCI-E x16, 4 DDR DIMM, Audio, Gigabit LAN) Chipset egenskaper: Hovedkort chipset nVIDIA nForce4 SLI, AMD Hammer Minne Tider 2.5-3-3-8 (CL-RCD-RP-RAS) Command Rate (CR) 1T SPD minne moduler: DIMM1: Corsair VS512MB400 512 Mb PC3200 DDR SDRAM (2.5-3-3-8 @ 200 MHz) DIMM2: Corsair VS512MB400 512 Mb PC3200 DDR SDRAM (2.5-3-3-8 @ 200 MHz) Skjermkort prosessor egenskaper: Skjermkort nVIDIA GeForce 6600 GT PCI-E GPU kodenavn NV43GT (PCI Express x16 10DE / 0140, Rev A2) GPU klokkehastighet 299 MHz Minne klokkehastighet 299 MHz Temperaturer: Hovedkort 35 °C (95 °F) CPU 41 °C (106 °F) GPU 44 °C (111 °F) GPU omgivelse 39 °C (102 °F) Minne modul egenskaper: Modul navn Corsair VS512MB400 Serienummer Ingen Modul størrelse 512 Mb (2 ranks, 4 banks) Modul type Unbuffered Minne type DDR SDRAM Minne hastighet PC3200 (200 MHz) Modul bredde 64 bit Modul spenning SSTL 2.5 Feil-detekterings metode Ingen Oppdateringsfrekvens Redusert (7.8 us), Self-Refresh Minne Tider: @ 200 MHz 2.5-3-3-8 (CL-RCD-RP-RAS) Lenke til kommentar
Sunni Skrevet 25. september 2006 Del Skrevet 25. september 2006 (endret) Her er en link som er et must å lese.Håper den kan hjelpe. http://www.viaarena.com/Default.aspx?PageID=5&ArticleID=9 Og her-- https://www.diskusjon.no/index.php?showtopi...8&s=hardware.no Endret 25. september 2006 av Sunni Lenke til kommentar
H.M.Kongen Skrevet 25. september 2006 Del Skrevet 25. september 2006 det første som slo meg var at skjermkortet går varmt,er det mulig tro?eller noe annet som blir varmt. Lenke til kommentar
Thor. Skrevet 25. september 2006 Del Skrevet 25. september 2006 Rens maskinen din for støv og se om det hjelper. Systemmeldingen du fikk om nv4_disp er fra skjermkortet men det er ikke sikkkert det er driveren som gjorde noe feil. Kan også være varme/andre ting som er det egentlige problemet. Åpne kabinettet du og fjern støv i første omgang Lenke til kommentar
Nemiz Skrevet 25. september 2006 Forfatter Del Skrevet 25. september 2006 Takker for svar. Har demontert hele maskina og støvsugd grundig. Deretter installerte jeg komponentene en etter en for å feilsøke. Etter at jeg setter inn skjermkortet får jeg den samme feilen. En annen ting er at jeg ikke ser noen monitor under device manager. Det oppstår også vertikale linjer på skjermen som vist på disse bildene: Jeg erstattet skjermkortet av type PCIe POV GeForce 6600GT med et gammelt ATI Graphics Mach 64 2MB PCI og maskina funker da som normalt. Bør jeg sende inn skjermkortet til reklamasjon? Det er rundt 1 år gammelt. Lenke til kommentar
Sunni Skrevet 25. september 2006 Del Skrevet 25. september 2006 Takker for svar. Har demontert hele maskina og støvsugd grundig. Deretter installerte jeg komponentene en etter en for å feilsøke. Etter at jeg setter inn skjermkortet får jeg den samme feilen. En annen ting er at jeg ikke ser noen monitor under device manager. Det oppstår også vertikale linjer på skjermen som vist på disse bildene: Jeg erstattet skjermkortet av type PCIe POV GeForce 6600GT med et gammelt ATI Graphics Mach 64 2MB PCI og maskina funker da som normalt. Bør jeg sende inn skjermkortet til reklamasjon? Det er rundt 1 år gammelt. 6935170[/snapback] Ja Lenke til kommentar
