AudunSæther Skrevet 23. september 2006 Del Skrevet 23. september 2006 (endret) Hepp. Oppdaterte kjernen og NVIDIA-driveren idag. Har en xorg-conf jeg alltid har brukt siden jeg fikk meg to skjermer, men nå får jeg kun ett skjermbilde. En bit av Xorg-loggen: Skjult tekst: (Marker innholdet i feltet for å se teksten): (II) Setting vga for screen 0.(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32 (==) NVIDIA(0): RGB weight 888 (==) NVIDIA(0): Default visual is TrueColor (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0) (**) NVIDIA(0): Option "TwinView" "true" (**) NVIDIA(0): Option "SecondMonitorHorizSync" "30-65" (**) NVIDIA(0): Option "SecondMonitorVertRefresh" "50-75" (**) NVIDIA(0): Option "MetaModes" "1280x1024,1280x1024" (**) NVIDIA(0): Enabling RENDER acceleration (**) NVIDIA(0): TwinView enabled (WW) NVIDIA(0): Unable to read EDID for display device CRT-0 (II) NVIDIA(0): NVIDIA GPU GeForce FX 5200 at PCI:2:1:0 (--) NVIDIA(0): VideoRAM: 131072 kBytes (--) NVIDIA(0): VideoBIOS: 04.34.20.23.00 (--) NVIDIA(0): Interlaced video modes are supported on this GPU (--) NVIDIA(0): Connected display device(s) on GeForce FX 5200 at PCI:2:1:0: (--) NVIDIA(0): CRT-0 (--) NVIDIA(0): Samsung SyncMaster (CRT-1) (--) NVIDIA(0): CRT-0: 350.0 MHz maximum pixel clock (--) NVIDIA(0): Samsung SyncMaster (CRT-1): 350.0 MHz maximum pixel clock (II) NVIDIA(0): Assigned Display Devices: CRT-0, CRT-1 (II) NVIDIA(0): Validated modes: (II) NVIDIA(0): "1280x1024,1280x1024" (II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024 (WW) NVIDIA(0): Unable to get display device CRT-0's EDID; cannot compute DPI (WW) NVIDIA(0): from EDID. Xorg-config: Skjult tekst: (Marker innholdet i feltet for å se teksten): # /etc/X11/xorg.conf (xorg X Window System server configuration file)# # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "Files" FontPath "/usr/share/X11/fonts/misc" FontPath "/usr/share/X11/fonts/cyrillic" FontPath "/usr/share/X11/fonts/100dpi/:unscaled" FontPath "/usr/share/X11/fonts/75dpi/:unscaled" FontPath "/usr/share/X11/fonts/Type1" FontPath "/usr/share/X11/fonts/CID" FontPath "/usr/share/X11/fonts/100dpi" FontPath "/usr/share/X11/fonts/75dpi" # paths to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" EndSection Section "Module" Load "GLcore" Load "i2c" Load "bitmap" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc104" Option "XkbLayout" "no" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "Device" Identifier "NVIDIA Corporation NV34 [GeForce FX 5200]" Driver "nvidia" BusID "PCI:2:1:0" Option "TwinView" "true" Option "MetaModes" "1280x1024,1280x1024" Option "SecondMonitorHorizSync" "30-65" Option "SecondMonitorVertRefresh" "50-75" EndSection Section "Monitor" Identifier "SyncMaster" Option "DPMS" EndSection Section "Screen" Identifier "Default Screen" Device "NVIDIA Corporation NV34 [GeForce FX 5200]" Monitor "SyncMaster" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 4 Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 8 Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 15 Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 16 Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection SubSection "Display" Depth 24 Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" EndSection Section "DRI" Mode 0666 EndSection Det er to likedane Samsung Syncmaster 710v, men på den ene skjermen får den altså ikke tak i DPI-informasjon (noe som jeg ikke aner hva er, men). Så, jeg sitter litt fast med hva jeg skal gjøre Distro er Ubuntu-dapper. Endret 23. september 2006 av Izte Lenke til kommentar
