Tråden for romfergeoppdraget STS-116
Oppdatering fra Kenedy Space Center...
Kommer tilbake med bilder av ET/SRB mate senere i helgen... :cool:
Mission: STS-116 - 20th International Space Station Flight (12A.1) -
P5 Truss Segment
Vehicle: Discovery (OV-103)
Launch Date: No earlier than Dec. 7, 2006
Launch Pad: 39B
Crew: Polansky, Oefelein, Curbeam, Higginbotham, Patrick, Fuglesang
and Williams
Inclination/Orbit Altitude: 51.6 degrees/122 nautical miles
Technicians continue performing final closeouts on Discovery in
preparation for rollover to the Vehicle Assembly Building, currently
scheduled for Nov. 1. Leak checks of the crew module and external
airlock hatch are scheduled for Sunday. The work to repair the damage
to orbiter Discovery's right-hand external tank door mechanism is
nearly finished. Servicing is complete on the environmental control
and life support system.
The STS-116 crew is at Kennedy Space Center for the payload and
orbiter crew equipment interface test. A routine part of astronaut
training and launch preparations, the test activities allow for
equipment familiarization and inspection of the items and hardware
that will be used during the mission.
In the Vehicle Assembly Building, the external tank scheduled to fly
with Discovery was mated to the solid rocket boosters early this
morning during third shift. Technicians will complete closeouts in
preparation for orbiter Discovery to be mated to the tank, designated
ET-123, on Nov. 1.
Her er oppdateringene fra Kenedy Space Center denne uken:
P5 Truss Segment
Launch Pad: 39B
and Williams
scheduled for Nov. 1. The work to repair the damage to orbiter
Discovery's right-hand external tank door mechanism is finished and
the door functional test is complete.
The team plans to complete orbiter aft closeouts this weekend. The
right- and left-hand wing box and wing doors were installed for
flight on Thursday. The Ku-band antenna test was successfully
completed, and the antenna was stowed for flight on Wednesday.
In the Vehicle Assembly Building, technicians will complete closeouts
in preparation for orbiter Discovery to be mated to the tank,
designated ET-123, on Nov. 1.
Astronautene var også innom KSC for å ta en titt på utstyret de skal bruke, og på Discovery:
Her er dem i en "kurv" over lasterommet til Discovery. Den personen i midten med hvit lue er Christer Fuglesang (svensken)
Her har vi noen av astronautene mens de titter under discovery. Her inspiseres kamra-utstyr som brukes til å ta bilder av flisene på varmesjoldet til romfergen.
  • 2 uker senere...
Etter planen skal Discovert flyttes fra orbiter processing facilllity (OPF) til Veichle Assembly Buildning (VAB) hvor den skal festes til tanken og startrakettene.
Dette er planlagt i natt eller tidlig imorgen norsk tid. Skal prøve å komme med noen bilder av dette.
Ellers er det også verdt å få med seg en annen god nyhet idag. NASA har godkjent et siste service oppdrag på Hubble teleskopet. Oppdraget heter STS-125, og planlegges våren 2008. Etter planen er det Discovery som skal fly dette oppdraget.
http://www.nasa.gov/home/hqnews/2006/oct/H...nouncement.html
Andre nyheter vi kan nevne idag er at P5 delen av romstasjonen som Discovery skal ha med seg opp har blitt flyttet fra lagringsplassen sin i SSPF til laste-containern som etter planen skal kjøres ut til oppskytningsrampen en dag før Discovery.
P5 er en liten "adapter" som skal monteres mellom P3/P4 solcelle-panelet som Atlantis hadde med opp i september, og P6 som etterhvert skal monteres utenpå.
Internett var nede hjemme i leiligheten min i går... Fikk derfor ikke kommet med bilder fra roll-over, men her er det:
Discovery, her på vei ut av hangaren (OPF) hvor hun har blitt velikeholdt siden landingen i Florida i slutten av Juli i år.
Romfergen fraktes på en transporter. Turen fra hangaren over til bygngen hvor den monteres til tank og startraketter tar omtrent 30 minutter
Etter at romfergen er fremme så festes den til en spessielt kran som løfter den opp, og heiser den vertikalt.
Endret av [GDI]Raptor
Her er Discovery i vertikal posisjon klar til å bli løftet over til tanken og startrakettene.
Discovery heises ned for å monteres til tanken. Dette er en tidkrevende prosess.
NASA kommer også til å kjøre tester på tilkoblingene mellom tanken og romfergen. Det er ikke bare to enorme rør som leder flytende oksygen og hydrogen, men også ganske mange kabler.
Det installeres også kamraer forskjellige steder på romfergen. Disse skal kunne ta bilder av tanken når romfergen separeres fra den i verdensrommet.
Lasten som skal være med Discovery opp til romstasjonen gjøres klar, og skal normalt kjøres ut til oppskytningsramen 1 dag før Discovery. Lasten monteres inn i discovery ute på oppskytningsrampen.
Den 7. november skal etter planen Discovery kjøres ut til oppskytningsrampen. Discovery skal bruke samme rampe som Atlantis brukte i september, altså rampe 39B.
Ny oppdatering:
Lasten som Discovery skal ha med opp til romstasjonen er nå kjørt ut til oppskytningsrampen.
Lasten installeres i lasterommet til Discovery når romfergen har kommet ut til oppskytningsrampen. Dette skal etter planen skje imorgen.
1 måned igjen til planlagt oppskytning nå!! :thumbup:
Sånn!
Nå har de kjørt ut romfergen fra VAB, hvor den har blitt montert til tanken sin ut til oppskytningsrampen. Selve turen ut begynte litt over midnatt idag (lokal tid) og turen ut til rampen tar 8 timer.
Klokken 8 var Discovery festet til oppskytningsrampen.
Planene fremover nå er det som kalles en "hot-fire" på romfergens tre APU'er. Disse driver hydraulikk systemet. Etter "hot-fire" er ferdig, så taes den roterende service strukturen (RSS) rundt romfergen for å beskytte den for vær og vind.
Planene den kommende uken er:
- Installasjon av last i Discovery sitt lasterom
- Verifisere koblinger mellom romferge og oppskytningsrampe
- Fylle drivstoff på romfergens mini-jet's (RCS) som de bruker til å styre med i verdensrommet
Tar med noen flere bilder fra roll-out idag:
Nok en oppdatering:
De siste tre dagene har astronautene vært på Kenedy Space Center på det som kalles Terminal Countdown and Demonstration Test (TCDT). Dette er en test hvor de simulerer en ekte nedtelling, med ett avbrudd på T-10 sekunder.
Astronautene får også mulighet til å teste diverse metoder for å rømme fra oppskytningsrampen i et nødstilfelle, og det er også mulighet for å titte på lasten de har med ombord i romfergen.
Legger med et bilde av Crister Fuglesang, ved luken til Discovery.
3 uker igjen til oppskytning idag!! :thumbup:
Updatering igjen fra Kenedy Space Center, hvor de idag avslutter TCDT. Dørene på lasterommet har også blitt lukket for siste gang før oppskytning.
P5 Truss Segment
Launch Pad: 39B
and Williams
Following Space Shuttle Discovery's arrival at Launch Pad 39B on Nov.
9, technicians began final preparations for the STS-116 launch to the
International Space Station set for no earlier than Dec. 7. At the
pad, the payload was installed into the payload bay on Nov. 11, and
the payload/orbiter interface test was completed this week. On
Thursday, the remote manipulator system and orbiter boom sensor
system were stowed and the payload bay doors were closed for flight
late that night.
This week, the seven-member crew of STS-116 took part in the terminal
countdown demonstration test activities at Kennedy Space Center. The
astronauts arrived on Monday and returned to Johnson Space Center in
Houston on Thursday afternoon. On Tuesday and Wednesday, the crew
practiced driving in the M113 armored personnel carrier, and
participated in fire suppression training and flight crew equipment
fit checks. The crew also had the opportunity to go to the pad for
the emergency egress and payload bay "walkdowns." On Thursday, the
astronauts donned their launch and entry suits and entered the
vehicle for a simulated countdown.
Today, technicians are beginning preparations for the prelaunch
propellant servicing scheduled to begin this weekend. This process
includes loading the fuel (monomethyl hydrazine) and oxidizer
(nitrogen tetroxide) into the orbiter maneuvering system and the
forward reaction control system. It also includes the loading of
hydrazine in the auxiliary power units on the orbiter and the solid
rocket boosters.
Dørene til lasterommet blir lukket før oppskytning:
Astronautene på oppskytningsrampen etter avsluttet TCDT:
Forøvrig, mange astronauter!
7324372[/snapback]
Jepp, på ett romfergeoppdrag er det vanlig med mellom 6 og 7 astronauter. Det har vel ved en annleding også vært 8 ombord på et oppdrag hjem fra MIR.
På dette oppdraget (STS-116) skal en av astronautene (Williams) være igjen på romstasjonen, og Thomas Reiter (som var med Discovery opp i juli) skal være med hjem.
Her kommer forresten oppdateringen fra KSC:
P5 Truss Segment
Launch Pad: 39B
and Williams
This week at Launch Pad 39B, technicians completed prelaunch
propellant servicing in preparation for Space Shuttle Discovery's
launch to the International Space Station, set for no earlier than
Dec. 7. This servicing includes loading the fuel (monomethyl
hydrazine) and oxidizer (nitrogen tetroxide) into the orbital
maneuvering system and the forward reaction control system. It also
includes loading hydrazine in the solid rocket boosters and the
auxiliary power units on the orbiter.
Space shuttle main engine ball seal leak checks were completed today.
Crew cabin and SPACEHAB leak checks are planned for Sunday.
On Nov. 28 and 29, NASA managers will hold the traditional Flight
Readiness Review at Kennedy Space Center. The review is a two-day
assessment of preparations for Discovery's mission and is designed to
produce a number of key decisions about the assembly flight,
including selection of an official launch date.
If the decision is made to proceed for the opening of the launch
window, the seven-member crew will arrive for launch at the Shuttle
Landing Facility the afternoon of Dec. 3.
29. november, etter det NASA kaller ett Flight Readiness Review (FRR) blir eksakt oppskytningsdato og tidspunkt annonsert. Hvis de går for åpningen av vinduet er det nå kun 14. dager igjen!! :thumbup:
