Overføre Karakter fra konto-til konto?
Hei..
Jeg og broren min har spillt på en "felles" WoW konto, vi begge har en lvl 60 hver og nå har jeg kjøpt meg en egen pc og egen WoW konto=)
Så jeg lurer på om det er mulig og overføre min rouge fra hans/vår konto til min konto?
MVH Tom :)
6908478[/snapback]
Er kontoene registrert på samme bruker? Isåfall, ja. Koster 15 quid eller noe slikt, men du ticker bare "Account transfer" i boksen for Paid Character transfer. Hvis det ikke er samme eier registrert, tror jeg ikke det går.
Er det ikke slik at etternavn/adresse eller begge må være like?
Edit: Var eiere ja..
"Can I transfer characters from one account to another?
Yes, you can transfer characters not just between realms but also between accounts. However, you may only request character transfers from one account where you are the owner to another account where you are the owner. Any attempt to transfer a character from an account where you are not the owner could be considered a violation of the World of Warcraft Terms of Use and could lead to Blizzard taking disciplinary action against your account, including, but not limited to warnings, temporary account suspension, or permanent account suspension, as determined by Blizzard.
To initiate a transfer between two of your accounts, you will need to specify the account name associated with the account you wish to transfer your character to, and answer the secret question for the destination account Please contact our billing department directly if there are any problems with your transfer.
Who is eligible for account to account transfers?
Transfers between accounts are only allowed between one account where you are the owner to another account where you are the owner. To initiate an "account to account" transfer, you will have to answer the secret question for each account, and the last name of each account holder must match."
Endret av Torinogut
Det er fult mulig ja, du skriver inn navnet på accounten du vil flytte den ene characteren til , så må du skrive inn svaret på secret hint på den andre accounten, å vips 1-2 time seinere så har du flytta den over
6913613[/snapback]
Du er klar over at Account - Account går igjennom en manuell sjekk før det godkjennes? Og at du risikerer å få kontoen din banna hvis du ikke er eieren av den andre kontoen?
Jeg har prata med Blizz om det...
som sagt, account går på etternavn..
Så om ikke bror din av en eller annen merkelig grunn heter noe annet til etternavn skal det gå bra. Eneste du trenger å vite er svaret på det hemmelige spørsmålet...
Jeg har også 2 kamerater som er brødre som har bytte chars, var ikke noe problem, de bor 2 forskjellige steder og betaler med forskjellige Visakort..
6914365[/snapback]
Så hvis man heter "Hansen" eller "Olsen" så er jo det en åpenbar fordel..
