Unreal Tournament 2003 v2136 patch
Jah...så er UT2k3 patchen ENDELIG kommet og har fått ei lang fix-liste.
Patch en er på 10.3MB og kan lases ned fra
http://www.bluesnews.com/files/ut2003/2136patch.shtml
[*]http://unreal.epicgames.com/files/ut2003-WinPatch2136Release.exe
Og her er changelisten:
Quote:
CHANGE LIST
Gameplay:
- suicides count against team score in TDM
- fixed attenuation flak chunk damage over distance
- reduced minigun spin up time slightly
- made shock beam effect thicker
- always keep dynamic light for shock projectile, even in low detail mode
- translocation destination adjustment bug fix
- "kdraw collision" disabled in MP
- player dies before ball gets through hoop should still get credit for throw
- fixed redeemer point blank shots
- double tap time invariant to gamespeed
- get rid of 03_2 use (duplicate of "three" sound)
- fixed problems with overtime not ending on first score in some situations
- fixed transloc camera sometimes taking two taps
- fixed 4 rocket bug
- fixed instagib really is instaGIB
- fixed 10 seconds before can speak again
- fixed killz in CTF-December, CTF-Face3, CTF-Citadel, and BR-IceFields
- clamped max view bob
- fixed tokara forest switching to CTF
- fix for balllauncher switchaway bug
- fixed problem with teammates grabbing the flag right when you score
- fixed No Adrenaline mutator not allowing other mutators to work
- fixed getting correct bots on configured bot games with no bots on one team
- fixed falling damage bug
- straightened lightning bolt (purely visual change to make it easier to see where you're shooting)
- fixed shieldgun impact charging effect fps slowdown
- Fix bug where ragdolls didn't turn skeletal when they fall into lava volume.
- If there is no momentum on death, add a small random one. Reduces ragdolls just falling to their knees.
- added mouse acceleration for improved fine aiming control. Can be turned on by adding the following line to the [Engine.PlayerInput] section in user.ini:
MouseAccelThreshold=+100.0
- added "now viewing" message when spectating
- Fixed: At end of match it says "You've lost the match" while spectating
- assault grenade faster minimum muzzle velocity
- fixed water footstep sounds sometimes not playing when touching fluidsurfaceinfo
- no behindview cheat in net games
- Simplified using custom ragdolls. 'Ragdoll=xxxx' in the .upl file now overrides the species ragdoll asset for the character. This approach is compatible with the cheat protection.
- Fix screwed-up vehicle camera.
- increased skeletal mesh pool vertex buffer lifetime from 500 to 1000 frames
- rocket smoke trail whiter
- rocket launcher max ammo now 30
- improved instagib beams
- no shooting through people in classic instagib (just like it was in UT), you can still shoot through them in zoom instagib
- fixed replicating blood spurts when hit
- improved sound positioning/attenuation
- fixed suicide spamming lagging servers
- fixed AI slowdown when can't reach player's location
HUD/Menus:
- typed messages stay up on HUD longer
- don't limit chat when game is paused
- fixed joystick support in menus
- added joystick hat support
- made sure "showlog" leaves fullscreen first
- new HUD options in menus:
Number of console messages shown
Console message font size
Ability to turn on and off various pieces of the HUD
Ability to scale the HUD
- Cut and Paste in Console and server browser/edit boxes.
- Change IForce to TouchSense Mouse Settings
- Added Min/Max players to Map Selection
- Added Author Name to Map Selection for Non-Epic maps
- Add Description field for Mod Authors and hooked it to the scrolly
- Added Announcer volume control to menus
- 'Speech' binder menu in Settings.
- Mouse wheel support on speech menu. On by default, but the ut2003.ini option bSpeechMenuUseMouseWheel turns it off.
- Letter key support in Speech Menu. The ut2003.ini option bSpeechMenuUseLetters turns this on, and you can specify what keys it uses in the .ini file as well.
- Fix [ALL] being at the bottom of the speech menu player list.
- fix for particle "priming"
- enabled "preferences" and made it leave fullscreen
- added support for Asian language keyboard input via IME
- added "TOGGLEREFRAST"
- 'Add IP' and 'Add Buddy' dialog's focus the edit box by default.
- can change crosshair color
AI:
- bots supporting player will grab nearby pickups
- fixed bots rotating to acquire targets too fast
- added ReactionTime parameter for bots
- fixed bots stuck in corners wanting to go to paths above
- bots go after adrenaline more
Editor:
- fixed editor crash when rebuild paths with new pickupbase
- UnrealEd works on Win98
Networking:
- added option to cap framerate in netplay (on by default). This improves client smoothness by keeping client physics updates more in sync with server. Its controlled in your UT2003.ini file in the [Engine.LevelInfo] section by bCapFramerate.
- improved ping measurement shown in scoreboard
- F6 bound to "stat net" again
- improved client movement on jumppads
- Buddy list wildcards
- Master server cheat protection MD5 support
- Removed server connect() 10054 warning
- servers no longer don't reconnect to master server on authentication failure
- Show server ip in server browser
- Remove ICMP logspam by default
- IRC client under 'Chat' tab in Server Browser.
- Added 'Server Browser' button in-game so you can view servers/chat without leaving game.
- Remove spurious qhull-related warnings at the console eg. when running a server.
- Removed a lot of server log spam
- added AdminSay function which works from log window
- overtime ends if no one left on server
- stats compatible with minplayers > 0 (stats start when number of bots drops to 0)
- fixed bug allowing bots to be added by admins in stats enabled games
- dedicated servers don't need to load skins/meshes/voices
- server CPU improvements (don't find actor channel reference twice)
- fixed server memory leak
Compatibility:
- fixed CD check problems on some machines
D3D
- fix for SiS 315 and other TnL cards only exposing one vertex stream
- better debug output for certain fatal failures
- better handling of running out of memory in default pool
- possible fix for UD3DRenderDevice::Unlock crash
- fix for "CreateVertexBuffer failed (D3DERR_INVALIDCALL)" crash
- made code respect D3DTEXOPCAPS_MODULATEALPHA_ADDCOLOR caps bit
- fixed case that led to an invalid stage setup in certain scenarios
- more Voodoo 3/5 & G400 workarounds (never sending more than 2 texcoords)
- better error message for UnSetRes
- changed error message for crash inside D3D8::DrawIndexedPrimitive
- now tries system memory pool if allocation in default pool fails
[ Denne Melding var redigert av: TST på 2002-10-30 14:12 ]
Jeg vil nødig fornærme deg B|Real, men er det noen spesiell grunn til at du bestandig har en eller annen grov feil i overskriftene du lager i trådene under "nyhetsnotiser"? Som jeg har nevnt utallige ganger før, publiseres disse overskriftene på forsiden vår, og vi setter pris på om folk er litt mer varsomme og sjekker for skrivefeil. Når man ikke engang skriver tittelen på spillet korrekt, syns vi det er litt slapp holdning. Nesten respektløst. Jeg har redigert en god del tråder du har startet i denne kategorien, og ber deg vennligst skjerpe deg litt.
Quote:
Den 2002-10-30 14:15, skrev TST:
Det var da voldsomt.. om denne fyren ikke fikk med seg en e i tournament eller hva det var, så er det vel ikke verdens undergang..
Folk som deg skulle hatt en alarm som gikk hver gang du skrev feil på ICQ eller mIRC eller noe.. helst en liten alarm som gav deg elektrisk støt hver gang du tastet noe inn feil... Så kunne du sett hvor plagsomt det hadde vært!
Norsklærere er det nok av på skolen... trengs ikke flere!!!
For det første er Tournament engelsk, og for det andre er det tydligvis ikke nok norsk/engelsk lærere i skolen, folk kan jo ikke skrive!
Dessuten, var dette en tittel på et spill, altså et egen-navn det var snakk om, og det er det en fordel å skrive det riktig. Man kan også søke etter tråder på forumet tror jeg, og da er det kjipt å søke etter riktig ord, når du egentlig leter etter noe som er feil stavet! SEE?
Jeg syns folk som ikke kan skrive burde holde seg til å prate.
Jeg ser nå fremdeles ikke poenget i og være så pirkete da, oi jeg bomma på en tast eller manglet en bokstav, shit?
Dont really think so,
Det viktigeste er at folk forstår det
og du bør være takknemlig for at noen i det hele tatt gidder og Poste en post for og informere,
om det er Copy/Paste eller ikke har ingen ting og si, og ville informere og gå på et forum for og hjelpe andre, er en god ting, syntes nå jeg da.
