Smb.conf - debian
Joakim87
Heisann
Jeg skal sette opp en bilde server hjemme, med et mappe for hver bruker og en felles mappe...
Når man logger inn skal man altså få tilgang til sin mappe (Område) og felles mappen(område).
Men når man logger inn så får man tilgang til sin egen mappe men IKKE felles mappen, feil meldingen lyder som følger:
" \\debianserver\Felles is not accessible. You might not have permission to use this network resource, bla bla bla, Network accsess is denied"
min smb.conf ser ut som følger:
[global]
# The domain name
workgroup = Idunsvei
# The server's name
netbios name = debianserver
# Comment describing what the machine is
server string = debianserver
# Workstations will set their time by this server
time server = yes
# SECURITY AND LOGGING SETTINGS
this must be 'user' on a PDC
security = user
# Allow connections only from the local machine and the 10.0.0.* address range:
# (you'll want to change this if your network uses a different addressing range)
hosts allow = 127.0.0.1 192.168.0.
# Don't allow connections from any other IP address ranges than defined by 'hos$
hosts deny 0.0.0.0/0
# Only allow connections from ethernet cards and the loopback address:
interfaces = eth* lo
bind interfaces only = yes
# For Windows 2000/XP encrypted passwords
encrypt passwords = yes
# Provide logon scripts, home directories, etc as well as authentication
domain logons = yes
log file = /var/log/samba/log.%m
# log level = 2
# Put a capping on the size (in kB) of the log file
max log size = 100
# PDC and master browser settings
os level = 64 ; ensure this machine is consulted 1st regarding current browse l$
preferred master = yes
local master = yes
domain master = yes ; This defines it as the Primary Domain Controller
# User profiles and home directory.
# the local path to which the home ([HOMES]) directory will be connected
logon drive = H:
# Where 'profiles' = [profiles] further on
logon path = \\%L\profiles\%U
logon script = netlogon.bat ; the logon script, whose location is defined in [N$
# Define user mappings between this system and Windows systems.
# Without this you get asked for a password even if none is required
# username map = /etc/samba/users.map
# but if you've created SMB users on here you don't need it
# Fine-tuning Samba for increased speed on Linux systems
# SO_KEEPALIVE - sends a probe every 4 hours to check that a connection is stil$
# TCP_NODELAY -
# IPTOS_LOWDELAY -
# SO_SNDBUF=14596 - 14596 is roughly the best in most ciscumstances, it may be $
# SO_RCVBUF=14596 - same reason as above
socket options = TCP_NODELAY, IPTOS_LOWDELAY, SO_KEEPALIVE, SO_SNDBUF=14596, SO$
# Keep the case in file/directory names; when looking for a file
# matching is done without regard to case, as expected by Windows
preserve case = yes
short preserve case = yes
case sensitive = no
# (allows users to change their passwords)
unix password sync = yes
pam password change = yes
# --- shares ---
[profiles]
comment = Windows user profile directories
path = /home/samba/profiles
read only = no
browseable = no
create mode = 0600 ; rwx-xxx-xxx - only the user can read/write files
directory mode = 0700 ; rwx-xxx-xxx - directories must be executable if they ar$
[root]
# For administration purposes
path = /
browseable = yes
writeable = yes
valid users = joakim
[homes]
# 'logon drive' won't work without this section
# If you want to set the home directory somewhere other than the Unix home:
# path =
volume = HOME
comment = home directories
read only = no
# Don't display a 'homes' share as well as the '%U' share
browseable = no
public = no
create mode = 0750
[Felles]
path = /home/samba/
browseable = yes
writeable = yes
valid users = joakim, inger, jon, mie
[NETLOGON]
# Required for Windows authentication
comment = The domain logon service
path = /home/netlogon
read only = yes
# 'read only' can be changed to 'no' whilst you edit this file
# but revert back to 'yes' for normal secure operation
browseable = no
write list = @admins
Noen som kan hjelpe meg slik at allusers får accsess til felles?
På forhånd takk
man groupadd
eller hvis du er lat (er en stund siden jeg har gjort dette men tror det er ca riktig):
groupadd dingruppe
useradd -g gruppenavnetditt -d /home/dinbrukersbrukernavn dinbrukersbrukernavn
chown :gruppenavnetditt /home/samba
Endret av Lassie
