1rescue Skrevet 12. september 2006 Rapporter Del Skrevet 12. september 2006 Hallo, I dag begynte maskinen min å oppføre seg merkelig. Ved oppstart, kommer den til første bilde, så blinker skjermen, og maskinen rebooter. Dette skjer kanskje en 3 - 6 ganger før den endelig starter opp. Sendte en error msg til microsoft, og og fikk flkgende svar: Error caused by a video device driver Thank you for sending an error report to Microsoft. Error report summary <clip> Error type Windows stop error (A message appears on a blue screen with error code information) Solution available? Yes What does this error mean? You received this message because a device driver installed on your computer caused the Windows operating system to stop unexpectedly. This type of error is referred to as a "stop error." A stop error requires you to restart your computer. Cause A video adapter device driver Computer symptoms A message appears on a blue screen with error code information: STOP 0x000000EA THREAD_STUCK_IN_DEVICE_DRIVER - or - STOP: 0x100000EA THREAD_STUCK_IN_DEVICE_DRIVER_M Action for you to take We have analyzed your error report and there are two solutions for this problem for you to choose between. + Solution 1: Install the most current driver for your video card * Go to the Microsoft Update website to see if there are any updated drivers for your video card. A driver is software that enables hardware or devices (such as a printer, mouse, or keyboard) to work with your computer. Every device needs a driver in order for it to work. If there are any drivers listed, you should install them. * If there are no updated drivers at Microsoft Update, and you know the manufacturer of the video card, contact the card manufacturer's product support service for assistance. * If there are no updated drivers at Microsoft Update, you don't know the name of the manufacturer of the video card, and you need more help diagnosing and resolving this problem, contact your computer manufacturer's product support service. + Solution 2: Manually decrease Hardware Acceleration for your video adapter <clip> Ok, så der er noe med skjermkortet. Men, jeg har de nyeste driverne installert. Dette er jo et irriterende problem. Kjører på amd athlon 64 4200 x2 @2600mhz. 4gb ram Cosair, msi K8N SLI hovedkort, water cooling av prosessor, idle 36c - 38, 45c - 50 load, 4x250 samsung spinrite's = 1TB, 4xNorthQ Silent Tornado 92mm Fan, ati x1900xt, fortron epsilon 600w psu, og mye annet. Hva i all verden kan dette være .. har forsøkt å klokke ned, men det hjelper jo ikke i det hele tatt. Noen som har en god ide eller to?Aner ikke hva jeg skal gjøre akkurat nå :-( På forhånd takk for all hjelp! Erik Lenke til kommentar
Sunni Skrevet 12. september 2006 Rapporter Del Skrevet 12. september 2006 Har du innstallert noe programvare den siste tiden? Lenke til kommentar
