Explorer 7 reg feil !
Hei, Her om dagen da jeg skulle installere Explorer 7
fikk jeg en feil melding om at det var register feil og måtte sjekk e
denne siden
Gjore det meste og kom fram til at det var " IECUSTOM: Unwriteable key" som var galt..
[ie7.log]
1.062: =================================================
1.062: 2006/09/02 13:08:58.156 (local)
1.062: c:\2ee25d67ff5c9e9f0af90fc0ccbb7d\update\update.exe (version 6.2.29.0)
1.078: Hotfix started with following command line: /quiet /norestart /er /log:C:\WINDOWS
5.500: IECUSTOM: Scanning for proper registry permissions...
7.484: IECUSTOM: Scanning for proper registry permissions...
8.047: IECUSTOM: Scanning for proper registry permissions...
8.500: IECUSTOM: Unwriteable key HKCR\https
8.531: IECUSTOM: Unwriteable key HKCR\https
8.531: IECUSTOM: Unwriteable key HKCR\https\shell\open\command
8.672: IECUSTOM: Unwriteable key HKLM\SOFTWARE\Classes\https
8.672: IECUSTOM: Unwriteable key HKLM\SOFTWARE\Classes\https\shell\open\command
8.750: IECUSTOM: Backing up registry permissions...
8.766: IECUSTOM: Finished backing up registry permissions...
8.766: IECUSTOM: Setting new registry permissions...
8.781: IECUSTOM: Unable to clear DACLs HKLM\SOFTWARE\Classes\https
8.781: IECUSTOM: Finished setting new registry permissions...
8.781: IECUSTOM: An error occured verifying registry permissions. ERROR: 0x80070534
8.781: DoInstallation: CustomizeCall Failed: 0x3f5
8.797: IECUSTOM: Restoring registry permissions...
8.828: IECUSTOM: Finished restoring registry permissions...
8.844: Konfigurasjonsregisternøkkelen kan ikke skrives.
8.859: Internet Explorer 7 installation did not complete.
8.859: Update.exe extended error code = 0x3f5
2.109: ==============================================
2.125: 2006/09/10 22:09:46.640 (local)
2.125: c:\e9b37aff8b47548d6e82\update\update.exe (version 6.2.29.0)
2.219: Hotfix started with following command line: /quiet /norestart /er /log:C:\WINDOWS
12.015: IECUSTOM: Scanning for proper registry permissions...
14.031: IECUSTOM: Scanning for proper registry permissions...
14.453: IECUSTOM: Scanning for proper registry permissions...
14.890: IECUSTOM: Unwriteable key HKCR\https
14.890: IECUSTOM: Unwriteable key HKCR\https\shell\open\command
15.047: IECUSTOM: Unwriteable key HKLM\SOFTWARE\Classes\https
15.047: IECUSTOM: Unwriteable key HKLM\SOFTWARE\Classes\https\shell\open\command
15.109: IECUSTOM: Backing up registry permissions...
15.140: IECUSTOM: Finished backing up registry permissions...
15.140: IECUSTOM: Setting new registry permissions...
15.140: IECUSTOM: Unable to clear DACLs HKLM\SOFTWARE\Classes\https
15.140: IECUSTOM: Finished setting new registry permissions...
15.140: IECUSTOM: An error occured verifying registry permissions. ERROR: 0x80070534
15.140: DoInstallation: CustomizeCall Failed: 0x3f5
15.219: IECUSTOM: Restoring registry permissions...
15.515: IECUSTOM: Finished restoring registry permissions...
15.531: Konfigurasjonsregisternøkkelen kan ikke skrives.
15.531: Internet Explorer 7 installation did not complete.
15.531: Update.exe extended error code = 0x3f5
som var galt..
men problemet er at jeg veet ikke hva jeg skal gjøre vidre for og fikse problemet..
Finner de i registret , men vet ikke hva jeg skal gjøre med de!
Noen av dere som vet?
Endret av BlAsrN
  • 1 måned senere...
Her er problemet:
Du må bruke metode 2 på den siden du du nevnte.
Kort fortalt:
Starte regedit
Finne hver og en av de åtte "nøklene" over
Gi administrator fulle rettigheter på den mappen
Lykke til, jeg fikk det til på andre forsøk
  • 2 uker senere...
