harryy Skrevet 9. september 2006 Del Skrevet 9. september 2006 Problemet: Larry harry # mount /mnt/cdrom/ mount: No medium found Larry harry # mount /dev/cdrom /mnt/cdrom mount: No medium found Larry harry # mount /dev/cdrw /mnt/cdrom mount: No medium found Litt informasjon: Larry harry # cat /etc/fstab | sed -e '/^#/d; /^$/d' /dev/hda1 /boot ext2 defaults 1 2 /dev/hda2 none swap sw 0 0 /dev/hda3 / ext3 defaults 0 1 /dev/hda4 /home ext3 defaults 0 0 /dev/sda1 /mnt/usbdrive auto user,noauto,gid=plugdev,umask=0002 0 0 /dev/cdrom /mnt/cdrom auto ro,noauto,user,exec 0 0 /dev/fd0 /mnt/floppy auto rw,noauto,user,sync 0 0 none /proc proc defaults 0 0 none /dev/shm tmpfs defaults 0 0 Larry harry # ls /dev/hd* /dev/hda /dev/hda1 /dev/hda2 /dev/hda3 /dev/hda4 /dev/hdc Larry harry # ls /dev/cd* /dev/cdrom /dev/cdrw Larry harry # dmesg |grep hdc ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:pio, hdd:pio hdc: PLEXTOR CD-R PX-W1610A, ATAPI CD/DVD-ROM drive hdc: ATAPI 40X CD-ROM CD-R/RW drive, 2048kB Cache, DMA Larry ~ # hdparm /dev/hdc /dev/hdc: IO_support = 0 (default 16-bit) unmaskirq = 0 (off) using_dma = 1 (on) keepsettings = 0 (off) readonly = 0 (off) readahead = 256 (on) HDIO_GETGEO failed: Inappropriate ioctl for device Larry ~ # hdparm -i /dev/hdc /dev/hdc: Model=PLEXTOR CD-R PX-W1610A, FwRev=1.00, SerialNo= Config={ Fixed Removeable DTR<=5Mbs DTR>10Mbs nonMagnetic } RawCHS=0/0/0, TrkSize=0, SectSize=0, ECCbytes=0 BuffType=unknown, BuffSize=0kB, MaxMultSect=0 (maybe): CurCHS=0/0/0, CurSects=0, LBA=yes, LBAsects=0 IORDY=on/off, tPIO={min:180,w/IORDY:120}, tDMA={min:120,rec:120} PIO modes: pio0 pio1 pio2 pio3 pio4 DMA modes: sdma0 sdma1 sdma2 mdma0 mdma1 *mdma2 AdvancedPM=no * signifies the current active mode Er ikke 100% idiot: Kjører kommandoene som 'root'. CD platen funker på andre maskiner. CDrom'en funker, kan boote fra livecd. Har prøvd mount -t iso9660 -o ro /dev/cdrom /mnt/cdrom og alle lignende ting. /mnt/cdrom, /dev/cdrom og /dev/hdc eksisterer. Lenke til kommentar
Shruggie Skrevet 9. september 2006 Del Skrevet 9. september 2006 Har du sjekka at /dev/cdrom faktisk er linka til /dev/hdc? Har du prøvd å mounte /dev/hdc direkte? Lenke til kommentar
harryy Skrevet 9. september 2006 Forfatter Del Skrevet 9. september 2006 Sjekket og testet. Larry ~ # ls -l /dev/cdrom lrwxrwxrwx 1 root root 3 Sep 9 20:34 /dev/cdrom -> hdc Larry ~ # mount -t iso9660 /dev/hdc /mnt/cdrom/ mount: No medium found Lenke til kommentar
