hvordan få IE til å åpne maksimert?
dette er kanskje vel teit, men lurer likevel på hvordan jeg får stilt inn slik at Internet explorer åpner i maksimert form automatisk, feks når jeg trykker på linker osv. Når jeg starter IE går det greit, men når jeg trykker på linker åpnes de i "mellomstørrelse", slik at jeg må maksimere selv...
Hentet fra: http://www.5starsupport.com/faq/ie.htm
How can I have a window open maximized?
When opening a new window in IE ver 6 the new window opens minimized. I want all windows to open maximized so I don't have to go to task bar and right click and then hit max. any suggestions?
Sure. Windows has a memory, it will reopen a window the same way you had it last. You can take the minimized window and drag the edges by holding your mouse arrow over the edge of the window until you see two arrows, then left click and hold the left button while dragging the window to the desired size. Now close the window. It will now reopen each time with that setting.
To keep Windows functionality correct, drag the window into a small position while the minimize button in the top right corner (next to the "X") of the window is selected and drag the window to a large position while the button is in the maximized position. Make sure you perform this procedure one at a time so that Windows will save each setting.
