PlayStation 3-lansering utsatt (PS3)
Angående HDMI 1.x og 1080p sakser jeg fra HDMI.org
Q. What version of HDMI does a consumer need to view 1080p content?
HDMI has always supported 1080p resolution, starting from version 1.0 in 2002. However, as with many functions that HDMI enables (such as DVD-Audio and SACD), it is up to the manufacturer to choose whether to implement 1080p in the device. Some TV and device manufacturers have chosen not to implement 1080p in their products because 1080p content has not been widely available, and because changing the internal electronics of the device to support 1080p would increase cost.
Viewing 1080p resolution requires at minimum that the HDTV have a display supporting the 1080p pixel resolution. Today, many HDTVs use display technologies (such as PDP, LCD, and microdisplay screens) designed for 720p pixel resolution.
In addition, many of today’s 1080p HDTVs support only 720p or 1080i on the HDMI input, then perform video processing to up-convert the 720p/1080i signal to 1080p. This is now changing, as 1080p content is becoming increasingly available, and HDTVs fully supporting 1080p in the display and HDMI electronics have begun to reach the market in early 2006.
All versions of HDMI are backward compatible. Consumers should not look for a particular version of HDMI, but rather for the functionality that they want the device to support (SACD, 1080p, etc.).
regner med at flertallet (2 049 000 husholdninger i 2006) av norske husholdninger har Flat-TV samme tid neste år
Det vil nok ta noen år lenger enn det ja.
6853365[/snapback]
Hvordan regner du? 210 000 i 2005 over 500 000 i 2006 til sammen 710 000 ++
Husk det er solgt HDTV-er i 2004, 2003, etc også så jeg tipper de fleste husholdninger har HDTV innen våren 2007.
Regner med at salget på HDTV-er Jan2007-Sept2007 blir 400 000-500 000 fordi at salget øker hvert år.
6855553[/snapback]
Tror du virkelig at så mange vil kjøpe seg ny TV så fort? Folk kjøper ny TV når de trenger det, ikke fordi det er kommet en ny type. Og siden man IKKE trenger ny TV for å se de digitale bakkesendingene når de kommer, så tror jeg ikke at flesteparten av norges befolkning kjøper ny.
Husk at mange av TVene som selges går til husholdninger som har TV fra før også. Samt at det ikke er alle som har råd til en TV som koster 7-8000+
6853365[/snapback]
6855553[/snapback]
6878941[/snapback]
Hvis du vil ha faktatall omkring salg av HD-TV, se mine poster tidligere i tråden. Salgstall og tall fra TNS Gallup viser at Kameragutten har belegg for det han sier. Ellers ble vi enige om å la debatten omkring HD-Tv ligge i denne tråden.
6853365[/snapback]
6855553[/snapback]
6878941[/snapback]
6879611[/snapback]
Jupp jupp, har lagt den debatten død for respekt for andre på forumet her.
Uansett vil antatte salgstall i 2007 kun bli spekulasjoner...... vi får heller vente å se
:thumbup:
Edit: Håper ihvertfall det ikke blir noen utsettelse på Wii, har stor tro på den maskina... :yes:
Endret av Kameragutten
6896236[/snapback]
Tror det må skje noe helt ekstraordinært (som at fabrikkene brenner ned) for at Nintendo ikke overholder lanseringsdatoen nå. :)
6896432[/snapback]
Godt å høre, får håpe ikke noen Pyromaner fra Microsoft eller Sony er løs da :p
  • 1 måned senere...
