Hjelp til å installere driver for Plextor PXTV402U
Hei!
Kan noen hjelpe meg med å installer GO7007 driver for Plextor PX-TV402U i Ubuntu 6.06 DAPPER?
Har prøvd å finne en "How to" med hjelp av google, men uten hell.
Det jeg har funnet ut, med hjelp fra README filen (se nedenfor), er at jeg må konfigurere Kernel for så og installere driver.
Here is the link to the driver:
http://oss.wischip.com/
Fra README filen:
A fully built kernel source tree must be available.  Typically this will be
linked from "/lib/modules/<KERNEL VERSION>/build" for convenience.  If this
link does not exist, an extra parameter will need to be passed to the
`make` command.
All vendor-built kernels should already be configured properly.  However,
for custom-built kernels, the following options need to be enabled in the
kernel as built-in or modules:
        CONFIG_HOTPLUG           - Support for hot-pluggable devices
        CONFIG_MODULES           - Enable loadable module support
        CONFIG_KMOD              - Automatic kernel module loading
        CONFIG_FW_LOADER         - Hotplug firmware loading support
        CONFIG_I2C               - I2C support
        CONFIG_VIDEO_DEV         - Video For Linux
        CONFIG_SOUND             - Sound card support
        CONFIG_SND               - Advanced Linux Sound Architecture
        CONFIG_USB               - Support for Host-side USB
        CONFIG_USB_DEVICEFS      - USB device filesystem
        CONFIG_USB_EHCI_HCD      - EHCI HCD (USB 2.0) support
Additionally, to use the example application, the following options need to
be enabled in the ALSA section:
        CONFIG_SND_MIXER_OSS     - OSS Mixer API
        CONFIG_SND_PCM_OSS       - OSS PCM (digital audio) API
The hotplug scripts, along with the fxload utility, must also be installed.
These scripts can be obtained from <http://linux-hotplug.sourceforge.net/>.
Hotplugging is used for loading firmware into the Cypruss EZ-USB chip using
fxload and for loading firmware into the driver using the firmware agent.
Noen av spørsmålene jeg har:
Hvordan laster jeg ned den Kernel source jeg bruker?
Hvordan konfigurerer jeg Kernel source/headers?
Hvordan kompilerer man og installerer Kernel source/headers?
Jeg vet at når alt dette er gjort skal man bygge driveren med "sudo make install USE_DEV=y" siden hotplug er byttet ut med udev i Dapper.
hollowGod
Endret av hollowGod
Er dette et TV-kort?
Er du sikker på at driverne ikke ligger inne fra før, siden det er en GNU/GPL driver?
Det kan til og med hende at den ligger inne i pakkesystemet.
Sjekk ut: http://www.ubuntuguide.org
kernel-headers installerer du ved å søke på de i synaptic, høyreklikke, velge install og trykke APPLY i menyen.
Den alternative måten er å åpne en terminal og skrive:
sudo apt-get update
sudo apt-get install build-essentials kernel-headers
Viss du ikke kan dette, så synes jeg ikke du skal begynne å kompilere kernel-moduler fra kilde uten videre. Les ubuntuguide og søk på http://www.ubuntuforums.org og google om du finner en .deb pakke av driverne først, dersom du ikke finner de gjennom synaptic etter å ha vært gjennom ubuntuguide.org
Du må antageligvis gjennom en guide for å sette opp mythTV og gjøre endringer på /etc/X11/xorg.conf, søk på google.
Endret av Mental
OSV................
Takk for svaret + hjelp, skal prøve dette senere :)
hollowGod
