Når kmr dx10 kortene ?
lovealot
nVidia G80 GPU is expected to be released in H2. G80 expected to be released on TSMC's new 80nm process and will likely be the first DirectX 10 / Shader Model 4 compliant GPU on the market, indicating a total core redesign over G70/G71 and the implementation of a Unified Shader Model which processes vertices and pixels through the same dual purpose pipelines. In addition to SM4 support, improved SM3 performance and enhancements to the texture filtering engine are also expected. G80 clock speeds are expected to be around 700Mhz and the core will interface to GDDR4 memory.
ATI R600 GPU is expected to be released in October (perhaps later) on an 80nm (and perhaps 65nm too) process. The R600 is the successor to the R580 core and is expected to be built on a 65nm process and will be fully DirectX 10 compliant, utilising a Unified Shader Model architecture. Current rumours suggest that R600 will feature 64 Shader pipelines (processing both vertices and pixels) with 32 TMUs and 32 ROPs running at a clock speed of around 800Mhz.  R600 is expected to interface to 512MB of 1.8Ghz GDDR4 Memory over a 256-bit interface.
Dette er vel det nærmeste vi kommer noen som helst fakta, og selv disse har ingen konkret dato, og alt annet bør vel tas med en klype salt eller 2.
Men det er i hvertfall noe
