Trenger PSP 1.5 DOWNDATER folder [LØST]
ze5400
Nå som PSP 1.71 downgradernen har kommet lurte jeg på om noen som har 1.5 kunne være så snill å følge disse skrittene og sende meg DOWNGRADER mappa.
Instruction for the 1.50 user
1) Copy the folders downhelper and downhelper% from the folder 1.50 HELPER folder to
/PSP/GAME/ in your memstick.
2) Obtain the 1.50 updater and put it in /PSP/GAME/UPDATE in your memstick.
Some download links for it:
http://www.psphacks.net/files/PSPFirmwares/1.5/
3) Init the downhelper program.
It will dump your flash and some files from the updater eboot to the memstick.
4) After that, the program will exit. You can now delete the updater from /PSP/GAME/UPDATE
5) You'll notice that you have a new folder in the root of your memstick called "DOWNDATER".
That's the folder you'll have to send to a 2.71 to let him use the downdater.
Hvis noen kunne sende meg en PM med den DOWNDATER mappa ville jeg blitt kjempeglad :)
MERK: Sålangt jeg kan se er ikke dette å diskutere piratvare fordi det fins masse hjemmelagde programmer for 1.5 :)
Endret av ze5400
