Patience Skrevet 1. september 2006 Del Skrevet 1. september 2006 Er du mulig å TVINGE denne filen til å slutte med å vise hvit skrift på hvir bakgrunn? Kan jeg TVINGE skrifttypen til å bli sort? Er det noen der ute som kan skrive det hele om for meg? <?php /* * Gallery - a web based photo album viewer and editor * Copyright (C) 2000-2006 Bharat Mediratta * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or (at * your option) any later version. * * This program is distributed in the hope that it will be useful, but * WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU * General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 51 Franklin Street - Fifth Floor, Boston, MA 02110-1301, USA. * * $Id: add_photos.php 13338 2006-03-27 15:32:14Z jenst $ */ ?> <?php require_once(dirname(__FILE__) . '/init.php'); $mode = getRequestVar('mode'); // Hack check if (!$gallery->user->canAddToAlbum($gallery->album)) { echo _("You are not allowed to perform this action!"); exit; } $cookieName = $gallery->app->sessionVar . "_add_photos_mode"; $modeCookie = isset($_COOKIE[$cookieName]) ? $_COOKIE[$cookieName] : null; if (isset($mode)) { if ($modeCookie != $mode) { setcookie($cookieName, $mode, time()+60*60*24*365, "/" ); } } else { if (isset($modeCookie)) { $mode = $modeCookie; } } doctype(); ?> <html> <head> <title><?php echo _("Add Photos") ?></title> <?php common_header(); ?> <script type="text/javascript" language="Javascript"> <!-- function reloadPage() { document.count_form.submit(); return false; } // --> </script> </head> <body dir="<?php echo $gallery->direction ?>" onload="window.focus()" class="popupbody"> <div class="popuphead"><?php echo _("Add Photos") ?></div> <div class="popup"> <?php if (file_exists(dirname(__FILE__) . "/java/GalleryRemoteAppletMini.jar") && file_exists(dirname(__FILE__) . "/java/GalleryRemoteHTTPClient.jar")) { $modes["applet_mini"] = _("Applet"); if (file_exists(dirname(__FILE__) . "/java/GalleryRemoteApplet.jar")) { $modes["applet"] = _("Applet (big)"); } } $modes["form"] = _("Form"); $modes["url"] = _("URL"); $modes["other"] = _("Other"); if (!isset($mode) || !isset($modes[$mode])) { $mode = isset($modes[$gallery->app->uploadMode]) ? $gallery->app->uploadMode : "form"; } ?> <div id="container"> <ul id="tabnav"> <?php foreach ($modes as $m => $mt) { $url = makeGalleryUrl('add_photos.php', array('mode' => $m, 'type' => 'popup')); if ($m == $mode) { echo "\t\t<li><a href=\"$url\" class=\"active\">$mt</a></li>\n"; } else { echo "\t\t<li><a href=\"$url\">$mt</a></li>\n"; } } echo "\n\t</ul>"; include (dirname(__FILE__) . "/includes/add_photos/add_$mode.inc");?> </div> </div> </body> </html> Lenke til kommentar
Gjest Slettet-rXRozPkg Skrevet 1. september 2006 Del Skrevet 1. september 2006 Så vidt jeg kan se er det ikke satt noen farger noen steder i denne php-fila. Alt som er satt er noen klassenavn. Det er da bare å forandre i stilarket (som antagentlig blir inkludert med funksjonen common_header(). Lenke til kommentar
