kallis Skrevet 28. august 2006 Del Skrevet 28. august 2006 irriterer meg litt alle desse valgene av plater på dvdformatet. hva er egentlig forskjellen på - og + ? og hva er fordelen med dvdram, er det bare samme plata med beskyttelse? Lenke til kommentar
aQrubat Skrevet 28. august 2006 Del Skrevet 28. august 2006 dvd formater og stanard http://www.ntnu.no/multimedie/tjenester_ek...t_v3_110304.pdf Lenke til kommentar
Karamell Skrevet 28. august 2006 Del Skrevet 28. august 2006 (endret) les http://www.anandtech.com/guides/viewfaq.html?i=118 http://www.videohelp.com/dvd ==> DVD stands for Digital Versatile/Video Disc, DVDR stands for DVD Recordable and DVDRW for DVD ReWriteable. If you're familiar with regular audio/music CDs or regular DVD-Video discs, then you will know what a recordable DVD looks like. A recordable DVD stores up to 2 hours of very good quality DVD-Video, including several audio tracks in formats like stereo, Dolby Digital or DTS and also advanced menu systems, subtitles and still pictures that can be played by many standalone DVD Players and most computer DVD-ROMs. If you choose to lower the video quality it is possible to store several hours video on a recordable DVD using low bitrates and low resolution with video quality more like VHS, SVHS, SVCD, CVD or VCD. It is also possible to have up to 4.37* GB ordinary data or mix DVD-Video and data on a recordable DVD that can be played by most computer DVD-ROMs. There are three competing DVD Recording standards, DVD-R/DVD-RW and DVD+R/DVD+RW have pretty similiar features and are compatible with many standalone DVD Players and most DVD-ROMs while DVD-RAM has less DVD Player and DVD-ROM compatibility but better recording features. DVD-R and DVD-RW DVD-R was the first DVD recording format released that was compatible with standalone DVD Players. DVD-R is a non-rewriteable format and it is compatible with about 93% of all DVD Players and most DVD-ROMs. DVD-RW is a rewriteable format and it is compatible with about 80% of all DVD Players and most DVD-ROMs. DVD-R and DVD-RW supports single side 4.37 computer GB* DVDs(called DVD-5) and double sided 8.75 computer GB* DVDs(called DVD-10). These formats are supported by DVDForum. DVD+R and DVD+RW DVD+R is a non-rewritable format and it is compatible with about 89% of all DVD Players and most DVD-ROMs. DVD+RW is a rewritable format and is compatible with about 79% of all DVD Players and most DVD-ROMs. DVD+R and DVD+RW supports single side 4.37 computer GB* DVDs(called DVD-5) and double side 8.75 computer GB* DVDs(called DVD-10). These formats are supported by the DVD+RW Alliance. DVD+R DL DVD+R DL or called DVD+R9 is a Dual Layer writeable DVD+R. The dual layered discs can hold 7.95 computer GB* (called DVD-9) and dual layered double sides 15.9* computer GB (called dvd-18). DVD-R DL DVD-R DL or called DVD-R9 is a Dual Layer writeable DVD-R. The dual layered discs can hold 7.95 computer GB* (called DVD-9) and dual layered double sides 15.9* computer GB (called dvd-18). DVD-RAM DVD-RAM has the best recording features but it is not compatible with most DVD-ROM drives and DVD-Video players. Think more of it as a removable hard disk. DVD-RAM is usually used in some DVD Recorders. This format is supported by DVDForum. Read our DVD Writers and Recorders list and read also our DVD Players Compatibility list to see what types your standalone DVD Player supports. You find more detailed comparisons between the formats in the more info section here. Endret 28. august 2006 av Karamell Lenke til kommentar
kallis Skrevet 28. august 2006 Forfatter Del Skrevet 28. august 2006 hm. ja. men ingenting om hva den tekniske forskjellen på + - er. rart egentlig hvordan et format av samme dimensjon og lagring som går under samme navn ikke er kompatible med hverandre. Lenke til kommentar
Karamell Skrevet 28. august 2006 Del Skrevet 28. august 2006 hm. ja. men ingenting om hva den tekniske forskjellen på + - er.rart egentlig hvordan et format av samme dimensjon og lagring som går under samme navn ikke er kompatible med hverandre. 6762050[/snapback] Her: http://www.cdfreaks.com/article/113 kan du lese litt om tekniske forskjeller. Ikke akkurat lørdagsunderholdning. Og dessuten gammelt. Lenke til kommentar
Peppep Skrevet 19. november 2006 Del Skrevet 19. november 2006 Tar vanlige (stue-)DVD-spillere både DVD+R og DVD-R? Hvis ikke - hva er vanligst? Lenke til kommentar
HeltNils Skrevet 20. november 2006 Del Skrevet 20. november 2006 Tar vanlige (stue-)DVD-spillere både DVD+R og DVD-R? Ja, men for +R bør du sørge for at de blir brent som DVD-ROM, også kalt bitsetting. Ikke alle brennere støtter det. Søk i forumet eller på Google for å finne ut hvordan det gjøres. Lenke til kommentar
Peppep Skrevet 20. november 2006 Del Skrevet 20. november 2006 Da er vel det enkleste å bare gå for -R, og slippe problematikken med bisetting, eller er det andre ulemper med det? Lenke til kommentar
Jarmo Skrevet 20. november 2006 Del Skrevet 20. november 2006 En god emnetittel er en tittel som forklarer godt hva innholdet i posten din går ut på. En bruker bør kunne skaffe seg oversikt over hovedinnholdet i posten bare ut fra å lese tittelen. Emnetittelen i denne tråden er ikke god nok, om ikke dette blir endret slik at det er lettere å forstå hva slags informasjon tråden omhandler vil denne bli stengt! Vennligst forsøk å ha dette i tankene neste gang du starter en tråd, og orienter deg om hva vår nettikette sier om dårlig bruk av emnetitler. Tråden bryter også med tre-ords-regelen. Bruk -knappen i første post for å endre emnetittelen. (Dette innlegget vil bli fjernet ved endring av emnetittel. Vennligst ikke kommenter dette innlegget, men rapporter gjerne dette innlegget når tittelen er endret, så vil det bli fjernet.) Lenke til kommentar
