olemedkrutt Skrevet 25. august 2006 Del Skrevet 25. august 2006 #include <stdio.h> #include "winsock2.h" #include <iostream> #include <fstream> #include <windows.h> using namespace std; int main(int argc, char *argv[]) { // MessageBox(NULL, "hallo", "socketIndication", MB_OK); if(argc!=3) { cout<<"Usage:"; return 1; } // Initialize Winsock. WSADATA wsaData; int iResult = WSAStartup( MAKEWORD(2,2), &wsaData ); if ( iResult != NO_ERROR ) printf("Error at WSAStartup()\n"); // Create a socket. SOCKET m_socket; m_socket = socket( AF_INET, SOCK_STREAM, IPPROTO_TCP ); if ( m_socket == INVALID_SOCKET ) { printf( "Error at socket(): %ld\n", WSAGetLastError() ); WSACleanup(); return 1; } SOCKADDR_IN serverInfo; LPHOSTENT hostEntry; serverInfo.sin_family = AF_INET; hostEntry = gethostbyname("counter.rapidcounter.com"); // Specifying the server by its name; // another option is gethostbyaddr() (see below) if (!hostEntry) { WSACleanup(); } serverInfo.sin_addr = *((LPIN_ADDR)*hostEntry->h_addr_list); serverInfo.sin_port = htons(80); if ( connect( m_socket, (SOCKADDR*) &serverInfo, sizeof(serverInfo) ) == SOCKET_ERROR) { printf( "Failed to connect.\n" ); WSACleanup(); return 1; } char sendbuf[2000]="GET /counter/081"; strcat(sendbuf, " HTTP/1.1\r\nHost: "); strcat(sendbuf, "counter.rapidcounter.com"); strcat(sendbuf, "\r\nUser-Agent: who_cares?\r\n\r\n"); // strcat(sendbuf, "Referer: google.com\r\n"); // strcat(sendbuf, "Connection: close\r\n\r\n"); cout<< sendbuf << "\n"; char recvbuf[500]; int i=0; while(i!=200) { send( m_socket, sendbuf, sizeof(sendbuf), 0 ); } WSACleanup(); return 1; } Ja folkens, counteren blir altså ikke oppdatert. Har vel noe med at det er et bilde, eller jeg vet ikke. Noen som vet ? Lenke til kommentar
john.einar Skrevet 26. august 2006 Del Skrevet 26. august 2006 Du kan ikke ha doble newlines mellom ting i headeren. Aka du kan ikke ha \r\n 2x imellom User-Agent,Referer og Connection linjene. Du skal kun ha dobbel \r\n par etter siste header linje, aka etter Connection i din kode. Og ps: du har jo sagt til srv at connection skal closes etter request, så while loopen din vil ikke fungere. Lenke til kommentar
