Disable script debugging i IE hjelper ikke
Nå har jeg satt hake for disable script debugging i ie gudene vet hvor mange ganger. Men etter en stund kommer disse fordømte debug spørsmålene igjen og når jeg skjekker i options, er haken for disable script debuging borte igjen... Hvordan i all verden skal jeg få denne til å bli permanent??? Noen som har vært borti samme problem?
OS:WIN2K SP3(SP3 noe HERK)
IE:ver 6.0.2800.1106 SP1
Bruker Norton Internet Security 2002
The Edge
Er dette relevant? :
SYMPTOMS
When you disable script debugging in Internet Explorer and you view a Web page that contains script errors, you may continue to be prompted to debug the script.
CAUSE
This issue can occur if you have Microsoft Visual InterDev 6.0 installed on your computer and it is configured to debug scripts running in other programs.
RESOLUTION
To resolve this issue, use the following steps:
Open Visual InterDev 6.0.
On the Tools menu, click Options.
Double-click Debugger to expand the branch, and then click General.
Under Script, click to clear the Attach to programs running on this machine check box
