Ny gaming pc
har tittet litt på nettet og funnet denne pcen..
men hvis cpuen svekke systemet? denne pcen var like dyr som et conroe oppsett 6700 med 2 gb minne og et 7950 kort..
maskinen skal mesteparten brukes til spilling
bør jeg gå for denne eller et billigere amd 4400 oppsett med 2 x 7950 eller conroe oppsett med et 7950
denne kostet rundt 16000 ny, er vel ikke så gal pris det?
takker for svar
CPU Intel Pentium D Dual Core 3.6GHz 960 LGA 775 FSB800 2MBx2
Memory 4096MB 4(GB) DDR II 667 Memory 240 Pin (OCZ Gaming RAM)
Motherboard ASUS P5WD2 -E Premium Crossfire Ready
Hard Drive 1 Western Digital 250GB 7200RPM 16MB Cache Serial ATA II
Hard Drive 2 Western Digital 250GB 7200RPM 16MB Cache Serial ATA II
RAID These 2 hard drives can be setup as multi RAID
Optical Drive 1 LG 16X 4163B DVD RW + Dual Layer
Optical Drive 2 LG 16X 4163B DVD RW + Dual Layer
Crossfire Following 2 cards will run in Crossfire mode for optimal gaming experience with maximum FPS
Video 1 ATI Sapphire Radeon X1900 Crossfire Ed, PCI E, 512MB, DVI, TV
Video 2 ATI Sapphire Radeon X1900XTX, PCI Express, 512MB, 2xDVI, TV
Audio Realtek ALC 882, 8-channel High-Definition Audio CODEC
S/PDIF out interface
Network Card Dual 10/100/1000 Gigabit Lan Network Card
Neon Light 2 Sunbeam Cold Cathod Neon Light (blue)
Case Thermaltake Shark Full Tower Aluminum Case
Power Supply 560 Thermaltake SILENT Power Supply Dual Fan Control
okei =) ja kjedelige å kjøpe gamle dyre komponenter =)
CPU Intel Core 2 Duo Conroe E6400 2.13GHz FSB 1066, 2MB CPU
Memory 2048MB 2(GB) DDR II 667 Memory 240 Pin (Major Brand)
Motherboard ASUS P5B Mother Board
RAID These 2 hard drives can be setup as RAID 0 or 1
Optical Drive LG 16X 4163B DVD RW + Dual Layer
Video eVGA GeForce 7900 GT KO PCI-E 256MB DDR3 DVI.
Case Thermaltake Armor Jr. VC3000BWS(black)
Power Supply 500 Thermaltake SILENT Power Supply Dual Fan Control
men den her var søt, litt billigere og, men ikke så alt for mye, den over må jo være mye for pengene?
lars
Motherboard ASUS P5W DH Deluxe Mother Board CrossFire Ready
Case NZXT Appllo Classic Steel Case With 5.25LCD Device (black)
fant =)
dette må være bra oppsett?
16000 ca
driver å sjekker priser i utlandet.. og dem "råeste" er billigere i forhold til norge, mens de på mellom 10- 15 k er ca samme pris..
så den med crossfire oppsett er billig i forhold til norge.. kom på rundt 20 000 med alt mens koster 16500
Les igjennom Retningslinjene for denne kategorien.
Disse er også tydelig nemt i toppen av denne kategorien, samt at de ligger som eneste annonsering/sticky i denne kategorien!
En god emnetittel er en tittel som forklarer godt hva innholdet i posten din går ut på. En bruker bør kunne skaffe seg oversikt over hovedinnholdet i posten bare ut fra å lese tittelen. Emnetittelen i denne tråden er ikke godt nok, om ikke dette blir endret slik at det er lettere å forstå hva slags informasjon tråden omhandler vil denne bli stengt! Vennligst forsøk å tenk på dette neste gang du starter en tråd, og orienter deg om hva vår nettikette sier om dårlig bruk av emnetitler.
Bruk p_edit.gif-knappen i første post for å endre emnetittelen.
(Dette innlegget vil bli fjernet ved endring av emnetittel. Vennligst ikke kommenter dette innlegget, men rapporter gjerne dette innlegget når tittelen er endret, så vil det bli fjernet..)
