Hva brukes koffert til i XP?
The Briefcase feature in Windows XP helps you keep your files updated by automatically synchronizing multiple copies of individual files. In other words, Briefcase keeps track of the relationship between files on two or more computers. For example, if you use a desktop computer at the office, and you use a portable computer when you are on the road, Briefcase synchronizes and updates the files on your desktop computer to the modified versions when you reconnect your portable computer to the desktop computer.
http://support.microsoft.com/default.aspx?...kb;en-us;307885
