genstian Skrevet 25. august 2006 Rapporter Del Skrevet 25. august 2006 Ren matematikk vil være hardware avhengig, ja. Lenke til kommentar
Malvado Skrevet 2. september 2006 Rapporter Del Skrevet 2. september 2006 Nå som alt oppstyret rundt selve nyheten har dempet seg tenkte jeg egentlig at jeg skulle komme med et par observasjoner rundt denne teknologien. Selve teknologien er basert på å forandre på hvordan selve transistorene fungerer og hvordan man kan unngå problemene med dagens transistorer : Høy varmeutvikling, støy/lekasjer og begrensninger på grunn av dette. the Ballistic Deflection Transistor adds a new twist by bouncing the electrons into their chosen trajectories—using inertia to redirect for "free," instead of wrestling the electrons into place with brute energy. Such a chip would use very little power, create very little heat, be highly resistant to "noise" inherent in electronic systems, and should be easy to manufacture with current technologies. All that would make it incredibly fast. The National Science Foundation is so impressed with the idea that it just granted the University of Rochester team $1.1 million to develop a prototype. Teamet har vist allerede greid å Fabrikere en fungerende prototype I følge University of Rochester The team has already had some luck in fabricating a prototype. The ballistic transistor is a nano-scale structure, and so all but impossible to engineer just a few years ago. Its very design means that this "large" prototype is already nearly as small as the best conventional transistor designs coming out of Silicon Valley today. Feldman and Diduck are confident that the design will readily scale to much smaller dimensions. Bilde fra selve prototypen The BDT prototype was fabricated at the Cornell Nanofabrication Facility with the support provided by the Office of Naval Research. The $1.1 million is an NSF Nanotechnology Integrated Research Team grant, which is only awarded to promising research. The team is comprised of Marc Feldman, professor of electrical and computer engineering, Martin Margala and Paul Ampadu, assistant professors of electrical and computer engineering, and Yonathan Shapir, professor of physics and astronomy. Altså, det burde ikke være stor tvil lenger om at dette utviklingsprosjektet er seriøst og at om teknologien som brukes viser seg til å fungere som det skal så er det ikke lenge til vi kanskje faktisk ser radikalt nye design hvor dagens Cpu'er blir som snegler i forhold til det som kommer. Uansett, det kan være verdt å lese selve presseutalelsen fra selve universitetet enn å dra en konklusjon utifra hva selve journalistene skriver. University of Rochester Lenke til kommentar
Ripsta Skrevet 22. november 2006 Rapporter Del Skrevet 22. november 2006 Var det ikke IBM som annonserte for 5-6 år siden at de drev å forska på bruk av karbonrør som transistorer. Karbonrør er jo 1 nanometer i diameter, så da får man jo plass til en del av dem =) Lenke til kommentar
