Ubuntu: Feil skjermoppløsning på en eldre pc.
Hei!
Jeg la inn Ubuntu på enda en pc i dag, men problemet er at jeg ikke får kjørt ønsket oppløsning i ønsket frekvens.
Så jeg prøvde trikset med å sette # fremfor HorizSync og VertRefresh i xorg.conf. Men da gjorde den det verre og nå kjører den 1680x1050 i 60Hz på en gammel CRT-skjerm. Ingenting annet kan velges.
Hva bør jeg gjøre?
Om det betyr noe er det en ADI MicroScan 4v-skerm.
Jeg takker for alle svar.
Hilsen,
efikkan.
Post din xorg.conf
6722593[/snapback]
Her er den:Skjult tekst: (Marker innholdet i feltet for å se teksten):
Section "Files"
FontPath	"/usr/share/X11/fonts/misc"
FontPath	"/usr/share/X11/fonts/cyrillic"
FontPath	"/usr/share/X11/fonts/100dpi/:unscaled"
FontPath	"/usr/share/X11/fonts/75dpi/:unscaled"
FontPath	"/usr/share/X11/fonts/Type1"
FontPath	"/usr/share/X11/fonts/100dpi"
FontPath	"/usr/share/X11/fonts/75dpi"
# path to defoma fonts
FontPath	"/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load	"i2c"
Load	"bitmap"
Load	"ddc"
Load	"dri"
Load	"extmod"
Load	"freetype"
Load	"glx"
Load	"int10"
Load	"type1"
Load	"vbe"
EndSection
Section "InputDevice"
Identifier	"Generic Keyboard"
Driver  "kbd"
Option  "CoreKeyboard"
Option  "XkbRules"	"xorg"
Option  "XkbModel"	"pc105"
Option  "XkbLayout"	"no"
EndSection
Identifier	"Configured Mouse"
Driver  "mouse"
Option  "CorePointer"
Option  "Device"  "/dev/input/mice"
Option  "Protocol"  "ExplorerPS/2"
Option  "ZAxisMapping"  "4 5"
Option  "Emulate3Buttons"	"true"
EndSection
 Driver        "wacom"
 Identifier    "stylus"
 Option        "Device"        "/dev/wacom"          # Change to
                                                     # /dev/input/event
                                                     # for USB
 Option        "Type"          "stylus"
 Option        "ForceDevice"   "ISDV4"               # Tablet PC ONLY
EndSection
 Driver        "wacom"
 Identifier    "eraser"
                                                     # /dev/input/event
                                                     # for USB
 Option        "Type"          "eraser"
EndSection
 Driver        "wacom"
 Identifier    "cursor"
                                                     # /dev/input/event
                                                     # for USB
 Option        "Type"          "cursor"
EndSection
Section "Device"
Identifier	"NVIDIA Corporation NV6 [Vanta/Vanta LT]"
Driver  "nv"
BusID  "PCI:0:9:0"
EndSection
Section "Monitor"
Identifier	"Generic Monitor"
Option  "DPMS"
HorizSync	28-64
VertRefresh	43-160
EndSection
Section "Screen"
Identifier	"Default Screen"
Device  "NVIDIA Corporation NV6 [Vanta/Vanta LT]"
Monitor  "Generic Monitor"
DefaultDepth	24
SubSection "Display"
 Depth  1
 Modes  "1280x1024" "1024x768" "832x624" "800x600" "720x400" "640x480" "1x1"
EndSubSection
 Depth  4
EndSubSection
 Depth  8
EndSubSection
 Depth  15
EndSubSection
 Depth  16
EndSubSection
 Depth  24
 Modes  "1280x1024" "1280x960" "1024x768" "832x624" "800x600" "720x400" "640x480" "1x1"
EndSubSection
EndSection
Section "ServerLayout"
Identifier	"Default Layout"
Screen  "Default Screen"
InputDevice	"Generic Keyboard"
InputDevice	"Configured Mouse"
InputDevice     "stylus" "SendCoreEvents"
InputDevice     "cursor" "SendCoreEvents"
InputDevice     "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode	0666
EndSection
Har du prøvd med nvidia driveren, eller støtter den kanskje ikke kortet ditt? Ser at du ikke kjører den nå.
Regner med at du har prøvd å kommentere ut hsync og vrefresh etter at du har lagt til modes?
6725241[/snapback]
Jeg har prøvd nvidia-driveren.
Jeg prøve å kommentére de ut, og da ble den eneste oppløsningen 1680x1050i 60Hz med flimring som var grusomt på en 15" skjerm.
Etter mye dilling i xorg.conf fikk jeg til 1024x768 i 75Hz, men jeg fikk ikke til 1280x960 i 75Hz som jeg ønskte. Så pcen kan brukes uten problem, men om noen har idéer om hvordan jeg kan få det til (til senere bruk), så setter jeg pris på det.
6720764[/snapback]
1280x960 er ikke en normal oppløning, du er nødt til å bruke modelines.
Prøvd med modelines?
Her er noen guider for gentoo, men de kan brukes for ubuntu og:
http://gentoo-wiki.com/TIP_Getting_modelines
http://gentoo-wiki.com/HOWTO_Widescreen_Resolutions_(WSXGA)
For å intallere programmene du trenger i ubuntu:
sudo apt-get install read-id
6715278[/snapback]
