mofle Skrevet 19. august 2006 Del Skrevet 19. august 2006 mobileXBMC 2.0 by Sindre Sorhus Download Download it here! Description mobileXBMC is a very fast and simple webcontrol to XBMC, and with a lot of features. You can use it on a PDA, Computer and Cellphone (but with Opera Mini on the cellphone (sorry guys, it just couln't find a way to select music, pictures and videos without the ASP script, and I also had to use frameset)). You can use whatever connection you want as long as you can connect to the web withit (wlan, gprs, 3g, umts, or whatever...). Demo Try the demo here You can only look at it, because it have to be on a Xbox to work. Screenshots Current functions - Too many too write here, just try it out for yourself or test it in his demo. Known bugs - The left and right trigger remote doesn't work, therefor it isn't added. - I had to use frameset to remove the OK message from XBMC, somebody got another solution? mail me. - Both the ASP and the frameset make it impossible to run mobileXBMC on a wap cellphone. Installation Extract the .zip file, and drag the "web" folder into the XBMC folder on your XBOX. Remember to enable webserver in your XBMC settings. Configuration You can add and edit the "Launch apps/scripts" meny, by opening "appsmain.html" in f.eks notepad, and either edit one of the links that already is there, or copy one of them and then change it. Use it When you're ready, try it by going to http://IP:Port/ Use the port you chosed in the XBMC webserver settings. Example: http://193.215.150.121:200/ You can find your IP by visiting this page: http://www.whatismyip.com If you have a router remember to open/route the port of your xbmc webserver If you have any comments, questions, bugs, ideas, or something, contact me on: [email protected] with XBMC in the subject. mobileXBMC.zip Lenke til kommentar
