Catalyst 6.8 ute
Robin B
www.ati.com :)
Performance Improvement
As with most Catalyst® releases, performance has increased in various situations.
Improved shader compiler and transform engine optimizations have led to many significant performance gains in OpenGL applications across the entire Radeon® X1000 series of products. These include:
    * Doom 3 performance improves as much as 6.5%
    * Quake 4 (v1.2 or higher) performance improves as much as 18%
    * Chronicles of Riddick performance improves as much as 20%. Average improvements of 5-10% are commonly seen
    * Prey performance improves as much as 16%
Optimizations made to ATI's graphics memory manager have led to significant gains in DirectX applications that make heavy use of graphics memory on 256MB ATI graphics cards:
    * 3DMark06 performance improves as much as 22% on single ATI Radeon® X1000 series cards with 256MB of graphics memory at 1280x1024 and higher when anti-aliasing is enabled. The largest gains are found on the ATI Radeon® X1800 series and ATI Radeon® X1900 series of products
    * Call of Duty 2 performance improves as much as 30% on single ATI Radeon® X550 cards or higher with 256MB of video memory at 1280x1024 and higher when anti-aliasing enabled. The largest gains are found on the ATI Radeon® X1800 series and ATI Radeon® X1900 series of products
Bør også nevnes ny Linux driver, version 28.8.8 , denne skal blandt annet støtte flere distroer og er enklere å innstalere.
Burde kanskje nevne at samtlige Ati kort støttes nå av denne driveren, ytelsen er nok litt vanskelig for meg å beregne da jeg ikke har systemet helt oppe og går enda da det er et testsystem for meg.
Anbefaler noen linux guruer til å teste ut denne og komentere hvor bra den fungerer på diverse distroer, skal selv gi tilbakemelding når jeg har innstalert den på min Ubunto.
F-ord! Var ikke helt så enkelt å få denne til å fungere med mitt ubuntu oppsett nei, etter å ha brukt --listpkg og deretter sudo sh ati-driver-installer-28.8.8.run --buildpkg Ubuntu/6.06 så får jeg feilmelding 56 : error no such architecture. Ikke akkurat enkelt nei. Noen som har fått det til med ubuntu?
Endret av Malvado
  • 1 år senere...
Jeg er blitt anbefalt å installere catalyst og har gjort en del forsøk med diverse kommadoer i terminalen. Problemet er at jeg ikke finner igjen catalyst på maskinen etterpå. Er usikker på om jeg i det hele tatt har lykkes med installasjonen. Er det noen som kan anbefale en "idiotsikker" måte å gjøre dette på?
Nå skal det være sagt at jeg er veldig fersk med å bruke Ubuntu, men.....
Takker for tilbakemeldinger
