Hvordan finne fram til en pc via ip adresse?
Grrrrr,217.208.245.61 prøver å gi meg virus eller hacke meg,noen som vet hvordan jeg kan stoppe den "fyren"?
6766061[/snapback]
Fyren har i allefall internett hos Telia eller "skanova":
[kyrre@storeulv ~]$ dig -x 217.208.245.61
; <<>> DiG 9.3.2 <<>> -x 217.208.245.61
;; global options:  printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 26665
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2
;; QUESTION SECTION:
;61.245.208.217.in-addr.arpa.  IN      PTR
;; ANSWER SECTION:
61.245.208.217.in-addr.arpa. 86400 IN  PTR    h61n2c2o1028.bredband.skanova.com.
;; AUTHORITY SECTION:
245.208.217.in-addr.arpa. 86400 IN      NS      dns1.telia.com.
245.208.217.in-addr.arpa. 86400 IN      NS      dns2.telia.com.
;; ADDITIONAL SECTION:
dns1.telia.com.        61513  IN      A      194.22.190.10
dns2.telia.com.        61985  IN      A      194.22.194.14
;; Query time: 666 msec
;; SERVER: 130.67.15.198#53(130.67.15.198)
;; WHEN: Tue Aug 29 20:01:50 2006
;; MSG SIZE  rcvd: 168
Ett kjapt whois-oppslag avslører at Telia == Skanova:
[kyrre@storeulv ~]$ whois skanova.com
[Querying whois.internic.net]
[Redirected to whois.melbourneit.com]
[Querying whois.melbourneit.com]
[whois.melbourneit.com]
Domain Name.......... skanova.com
  Creation Date........ 2000-05-24
  Registration Date.... 2004-08-31
  Expiry Date.......... 2007-05-24
  Organisation Name.... TeliaSonera AB
  Organisation Address. Sturegatan 1
  Organisation Address. Stockholm
  Organisation Address. SE-106 63
  Organisation Address. -
  Organisation Address. SWEDEN
Admin Name........... Domain Manager
  Admin Address........ -
  Admin Address........ Gothenburg
  Admin Address........ SE-405 35
  Admin Address........ SWEDEN
  Admin Email.......... [email protected]
  Admin Phone.......... +46.850455000
  Admin Fax............ +46.86114642
Tech Name............ Registry Telia Net
  Tech Address......... Marbackagatan 11
  Tech Address......... Stockholm
  Tech Address......... SE-123 86
  Tech Address......... -
  Tech Address......... SWEDEN
  Tech Email........... [email protected]
  Tech Phone........... +46.84568930
  Tech Fax............. +46.84568935
  Name Server.......... DNS3.TELIA.COM
  Name Server.......... DNS4.TELIA.COM
[kyrre@storeulv ~]$
Oppslag på teila.com gir samme svar. Du kan jo prøve å sende en mail til [email protected], ettersom de ikke har oppgit noen "abuse" adresse.
Evt. så kan du gå inn på skanova.com -> kontakt og felannmellan -> Annmell missbruk av skanova internettkunder
Hvordan fikk du indikasjon på at denne ip'n var "aggressiv"? Post disse loggene eller hva det nå enn måtte være sammen med det, eller her, så kan vi hjelpe deg å annalysere.
Tar dette opp i denne tråden, da det passer fint her:
Nettsiden min blir stadig besøkt av IP 217.199.32.88. Hvis man taster den adressen inn i nettleseren, kommer man til "Mino". Nettsiden min er ikke registrert der, og eksisterer dermed ikke i deres synlige system. Men IP-adressen er blant de besøkende døgnet rundt. Den identifiserer seg ikke som en robot, og har ingen andre henvisere.
Jeg sendte dem en mail der jeg forklarte etiketten for robot-virksomhet, og spurte hvorfor de indekserer nettstedet. Fikk svar fra dem, hvor de spurte hvilken side det gjaldt. Jeg sendte dem svar på det, og har siden ikke hørt noe fra dem.
Hvordan går jeg frem for å bli kvitt dem?
Har blokkert IP-adressen slik at de alltid blir sendt til en blokkeringsmelding, men boten har ikke sluttet med besøkene sine.
Statistikk
Det er for øyeblikket 6 personer inne her. 1 er gjest, mens 4 av dem er pålogget.
Det er 1 robot inne og indekserer nettstedet.
Medlemmer:
neitakk| 30 august 2006  00:39| 30 august 2006  00:55| 16 minutter| aktive brukere| Windows XP| Opera| 194.248.x.x
(...snip...)
Gjester:
gjester 1| 30 august 2006  00:41| 30 august 2006  00:51| 10 minutter| aktive brukere| Unknown| Unknown| 217.199.32.88
Roboter:
Robot 1| 30 august 2006  00:37| 30 august 2006  00:47| 10 minutter| Waters vs. Gilmour?| Search Robot| Googlebot| 66.249.66.107
Edit: Til min forskrekkelse ser jeg nå at de etter å ha mottatt min mail, har lagt nettstedet inn i indekskatalogen. Kan de bare gjøre sånt uten videre? Virker meget useriøst...
Endret av neitakk
Kanskje .htaccess kan blokkere for IP'en hans? Jeg har ikke brukt .htaccess så mye at jeg vet om den kan, men det er vel mulig. Ellers er det vel bare å få webserveren til å videresende ham til masse forskjellige dritt-sider, eller la være å svare på forespursel.
Hei alle sammen! jeg lurte på hvordan det var mulig å finne fram til en pc via en ip adresse...sliter litt med en som skriver dritt på min side, og vil finne ut hvem det er....
Er det en enkel måte å gjøre det på?
Hilsen Joachim!
6699854[/snapback]
Bruker
Registrert: 16/08-2006
hmm
forresten, var det hjemmesia din det ble spamma på, å hva heter siden?
Har aldri fått .htaccess til å virke på den serveren. Men så er det en win2003-server som jeg ikke har annen tilgang på enn gjennom Helm Panel.
6772618[/snapback]
Jeg trodde .htaccess var noe som fungerte med Apache og ikke Win2003, mulig jeg husker feil da
6773245[/snapback]
Sant. Kansje prøve å bytte til apache-server? Evt. kansje IIS har noe liknende. *tukle med registeret* :p
Forøvrig, angående din signatur: Enkelte normale folk bruker alt for mye tid på f.eks. WoW. Jeg er glad jeg slipper, så jeg kan bruke alt for mye tid her istedet :p
6772618[/snapback]
6773245[/snapback]
win 2003 er ingen webserver. win 2003 kan fint kjøre apache.
6772618[/snapback]
6773245[/snapback]
6774192[/snapback]
Men ikke særlig bra - windows er mye treigere til å skifte mellom prosesser enn unix, som skifter like fort mellom prosesser og tråder. Og apache er skrevet for å bruke en drøss med prosesser...
