CHB3 Skrevet 16. august 2006 Del Skrevet 16. august 2006 Har vurdert å kjøpe en billig prosjektor til å se film og spille litt på. Det jeg har nu er en 20" CRT tv Så lurer på om denne prosjektoren er noe vits å kjøpe eller om det blir slik at jeg aldri kommer til å bruke den pga bildekvaliteten? http://www.komplett.no/k/ki.asp?sku=313870...BE-D2583A1CB52E Hva trur dere om den? Kom gjerne med forslag til andre prosjektorer til ca 5000 vist det finns noe bra til den prisen Lenke til kommentar
augulv Skrevet 17. august 2006 Del Skrevet 17. august 2006 Bortkasta Penger! Kjøp deg en Heller en Ny Projector Marantz VP-12 S4 Info om Projectoren(Engelsk) HD2+ DC3 (Dark Chip version 3), smoother surface, reduced distance >>> higher contrast, smoother image, 3 dimensional picture. Connectivity with 2x HDMI (DVI by adapters possible), 2x Component, S-Video, composite, VGA, RS232, 2x Trigger out, remote control bus Full video adjustment on all inputs including HDMI Extended Lens shift, 200% up, 100% down (from axial osition 1 full picture high up and a half down) New zoom function, factor 1.45, 250cm diagonal > 3,83m to 5,57m (previous 3.27m to 3,80m) Less operation noise, high mode 29dB , low mode 27dB New remote with direct buttons Power Off confirmation, power off button has to been press two times Blanking Screens, adjustable masking on button and top, left and right Orca filter for true colour reproduction 7 segment colour wheel (RGB,RGB, dark green NDF – natural density filter – reducing noise in green parts of the image – human being are most sensible on green and yellow and will easily detect any noise on it) NDF is only affective on dark green images and will not touch the total image at all. 200Watt DC super high pressure lamp – SHP Autocalibration – CT12 – half the time needed than on S3 (approx. 2 minutes) Gennum Video processing – GF9350 – VXD – Visual Excellence Processing - motion processing Lenke til kommentar
CHB3 Skrevet 17. august 2006 Forfatter Del Skrevet 17. august 2006 Ikke akutelt å kjøpe en prosjektor til 120k kr andre mer seriøse forslag? Lenke til kommentar
Ulf Isaksen Skrevet 26. august 2006 Del Skrevet 26. august 2006 mhm... hva prisklasse du forventer? Får mye prosjektor for feks. 10k. blant annet panasonic PE 900. Lenke til kommentar
CHB3 Skrevet 26. august 2006 Forfatter Del Skrevet 26. august 2006 10k er en ypperli prisklasse for meg. Men vil det bli såpass god prosjektore at det den forsvare et kjøp foran en Samsung 32"? Tenker da spesielt på bildekvalitet og filmfølelsen man får med det Lenke til kommentar
Martin-sama Skrevet 26. august 2006 Del Skrevet 26. august 2006 Får jo mer filmfølelse av en projektor uansett, sånn føler jeg det ihvertfall. Har omtrent den projektoren du linket til, hatt den i 1.5 år, og den funker bra, og jeg syntes den gir mye mer følelse enn en 32", eller en 42" for den saks skyld... Martin-sama Lenke til kommentar
Breiker Skrevet 27. august 2006 Del Skrevet 27. august 2006 (endret) den pj'n du har der er ikke verdt penga. Den støtter ikke hd signaler og har en elendig oppløsning. Ikke nok med det men det er det jeg liker å kalle en powerpoint pj. Som kun funker skikkelig til powerpoint presentasjoner der det er lite bevegelse i bildet. Den har forresten også et virkelig lavt kontrastforhold. Noe som vil gi dårlige farger og veldig dårlig dybde i bildet. Epson er elendig på en ting og det er dette: Epson har 90 dager lampegaranti fra kjøpsdato Hvis lampa ryker etter 3 måneder må du ut med rundt 3-4000kr for ny. Og da er det ikke verdt det for 5 flate øre. Så i dette tilfellet med denne pj'n er valget å gå for en 32" samsung LCD (av nyere og dyrere versjon) et mye bedre valg. MEN! hvis du skrur opp prisen litt og kjøper en bedre pj så vil du få et mye bedre resultat. Husk at lerrett også koster skjorta. Min pj osv: http://www.minhjemmekino.no/Breiker Noe mer du lurer på? Endret 27. august 2006 av Breiker Lenke til kommentar
Ulf Isaksen Skrevet 27. august 2006 Del Skrevet 27. august 2006 Vil andbefale deg en hd-ready prosjektor til dvd, xbox360, ps3 og nyere filmformater. Har veldig gode erfaringer med Panasonic sin. Bildene er veldig klare, lyse og fargerike. men skal du ha prosjektor bør du i dag har dvd spiller med hdmi eller komponentkabel Lenke til kommentar
LarsP Skrevet 28. august 2006 Del Skrevet 28. august 2006 Jeg er i allefall knallfornøyd med min Hitachi PJ-TX200. Prisen ligger i skrivende stund på kr.11.799,00 hos avshop.no. Lenke til kommentar
