Kappe alt for høy CPU-kjøler med vinkelsliper?
Torjus
Neppe. Hadde  bare tenkt å kappe 2-3 cm.
6682262[/snapback]
Heatpipes er ikke bare kobberstenger, fra Wikipedia:
A typical heat pipe consists of a sealed hollow tube. A thermoconductive metal such as copper or aluminium is used to make the tube. The pipe contains a relatively small quantity of a "working fluid" or coolant (such as water, ethanol or mercury) with the remainder of the pipe being filled with vapour phase of the working fluid, all other gases being excluded.
6682262[/snapback]
Kort fortalt er heatpipes rør med gass og litt veske av samme stoff, for eksempel vann etanol eller kvikksølv
