Slaves Skrevet 15. august 2006 Del Skrevet 15. august 2006 Har hatt problemer med cqmghost.exe på en HP server som kjører windows 2003 SBS. Etter en oppdatering av windows kom det en melding om at cqmghost.exe ikke kunne lese minne på en del lokasjoner,og valget mellom å avlutte eller debugge programmet. Er det noen som har vært borte i lignende,eller vet hvordan det kan man blir kvitt problemet? Lenke til kommentar
Jarmo Skrevet 15. august 2006 Del Skrevet 15. august 2006 Dette er info for XP, nå vet ikke om foldere er like i 2003. Description: File cqmghost.exe is located in a subfolder of C:\Windows\System32. Known file sizes on Windows XP are 18944 bytes (75% of all occurrence), 8208 bytes. The program is not visible. The file is not a Windows core file. cqmghost.exe is located in the Windows folder, but it is not a Windows core file. Program uses ports to connect to LAN or Internet. Therefore the technical security rating is 62% dangerous, however also read the users reviews. Important: Some malware camouflage themselves as cqmghost.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the cqmghost.exe process on your pc whether it is pest. We recommend Security Task Manager for verifying your computer's security. Lenke til kommentar
